Old 19th August 2004, 07:41 AM   #1
Default Does my basshorn look ok?
Does this look alright? Nothing horribly wrong here?
Will be run from 40Hz to 120 Hz.
CAD Drawing (haven't put the divider in, as I want to be able to paly with the back chamber volume.)
And, The pointless 3d Model, with my mid/top box ontop.
Old 19th August 2004, 03:04 PM   #2
Banned
Two points. First, you're modeling in .5 (eighth) space; the response will only be valid if you have your horn firing into a room corner. If you plan on using it as drawn you need to model in half space.
You're also going to some lengths to round off your reflectors. You only need to do that for frequencies above 200 Hz or so; it isn't necessary for lower frequencies.
When you model in half space you'll find your pathway will have to be much longer to get to 40 Hz, far longer than your folding scheme allows.
www.billfitzmaurice.com
Old 19th August 2004, 05:39 PM   #3
Coolin is offline Coolin  Netherlands
Coolin's Avatar
It wont make much of a difference for bass but i would try to load the driver more symetricaly.
What drivers are you using on top?
a new basshorn angeloitacare Subwoofers 7 9th June 2008 08:05 PM
Most musical basshorn 40 to 100 Hz rick57 Subwoofers 5 18th November 2005 01:08 AM
Avantgarde Basshorn angel Multi-Way 6 21st March 2004 01:54 AM
amp specifically for basshorn mikee12345 Solid State 2 6th August 2003 07:58 PM
Page generated in 0.07227 seconds (69.17% PHP - 30.83% MySQL) with 10 queries
