Need some help with sub woofer enclosure design port displacement Need some help with sub woofer enclosure design port displacement - diyAudio
Old 19th August 2004, 07:07 AM   #1
boxman75 is offline boxman75  United States
Default Need some help with sub woofer enclosure design port displacement
I am new here and may be posting this in the wrong place but I was wonder if someone could point me in the direction `of reading material web or other wise on the formulas and such for figuring out slot port displacements on various designs. For example a box that the port does not reach the back wall of the enclosure is easy but boxes where the port must turn inside the box or where the ports must make 3 or 4 walls is what I am looking for.
Thank you
Mat
below are some of the port configs i am talking about
Old 20th August 2004, 04:04 AM   #2
mikee12345 is offline mikee12345  New Zealand
mikee12345's Avatar
www.jlaudio.com 'tutorials'
http://www.bcae1.com/ scroll down to 116.
Need some help with sub woofer enclosure design port displacementHide this!Advertise here!
help!!! design a T-line enclosure for the "wrong woofer" ningures Multi-Way 4 7th October 2006 07:24 PM
Adding a Port to my enclosure Maples Multi-Way 6 26th July 2004 06:29 AM
Calculating woofer displacement eRiCdWoNg Multi-Way 5 20th April 2004 01:14 PM
enclosure port sma Subwoofers 4 24th January 2004 04:47 PM
how far away from the enclosure wall should my port be? slicemaster101 Subwoofers 1 15th April 2002 09:35 AM
Copyright 1999-2017 diyAudio
