Old 19th August 2004, 12:58 AM   #1
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
Default Active Speakers to cannibalize ?
Now that manufacturers like Advent are starting to come out with wireless active speakers for under $100/pr , does anyone know of any active speakers that contain a high enough quality chip amp to make them worth buying just to cannibalize and use the guts for DIY active speakers ?
Everyone has a photographic memory. It's just that most are out of film.
Old 19th August 2004, 01:27 AM   #2
Why not just buy these?
Sonic Impact introduces the first totally portable am capable of generating 15W per channel output from a fully battery operated source that fits in the palm of your hand and weighs less than one and a half pounds. Ideally suited for powering the SoundpaX speaker line by Sonic Impact. In stock March of 2003.
GENERAL DESCRIPTION
The TA2024 is a 15 W /ch continuous average two - channel Class - T Digital Audio
Power Amplifier IC using proprietary Digital Power Processing ™ technology.
Class - T amplifiers offer both the audio fidelity of Class - A B and the
power efficiency of Class – D amplifiers .
APPLICATIONS
· Battery Powered System
· Optional AC Adapter for 12 V power source
· No heat sink required up to 15W per channel
· Intelligent short circuit protection
· Connects to any passive 4/8 Ohm speakers
· Takes standard audio line input from any sound system
http://www.target.com/gp/detail.html...sin=B00009W44B
Old 19th August 2004, 02:19 AM   #3
Here's the chip that's in that amp. Kinda neeto?
http://www.tripath.com/downloads/TA2041.pdf
Davy Jones
Old 19th August 2004, 02:43 AM   #4
I've looked into Tripath amps before and they wanted $100 or so for an evaluation board. However, now that I know which Tripath amp is in the Sonic Impact 5066, I can't pass that up. I found some other cheaper sources.
$20.46 at http://www.efunctional.com/sit5066.html
with shipping, still under $30, not bad
Now it really makes sense to actively XO .
Old 19th August 2004, 04:27 AM   #5
Hybrid fourdoor's Avatar
Can also check out ebay for "active monitors" under Pro-Audio or home audio.
I enjoy my organic shapes.....
Old 19th August 2004, 06:00 AM   #6
SQ Kid is offline SQ Kid  United States
Send a message via AIM to SQ Kid Send a message via MSN to SQ Kid Send a message via Yahoo to SQ Kid
i believe apex jr has a few amps from powered Alesis monitors. havent checked the stie in a while, but i know i have seen full range amps on there for good prices
Old 21st August 2004, 03:50 PM   #7
HiSPL is offline HiSPL  United States
You could try this too.. http://www.envisionelectronics.com/products1.htm
I've heard some good things about it.....
Hey, do you hear that?
Old 21st August 2004, 06:20 PM   #8
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
Or this if you want a PA system:
http://www.partsexpress.com/pe/pshow...=300-797&DID=7
Old 6th October 2004, 03:47 AM   #9
CRFX is offline CRFX  United States
CRFX's Avatar
Send a message via AIM to CRFX
you wouldnt happen to know a source that sells these do you? Or even the TA2020?
If I'm reading the datasheet right i wont even need a heatsink since I won't push it past a watt or 2. (well at most a really small one)
I'm in the mood to break out the soldering iron.
It's easier to ask for forgiveness than for permission.
Old 6th October 2004, 05:47 AM   #10
Target has one of the 15 watt tripath amps in its $30 TAmp.
TAD active speakers A_TAD_Baffled Multi-Way 3 11th December 2007 02:04 PM
Active speakers DJ Sense Parts 1 8th June 2006 09:05 PM
Active speakers Mr Evil Multi-Way 10 15th October 2004 07:04 PM
Tube oscilloscope: use it, or cannibalize? cdwitmer Equipment & Tools 7 27th April 2003 05:23 PM
should a newbie restore this relic or cannibalize it zobsky Tubes / Valves 6 23rd March 2002 03:45 PM
Page generated in 0.11913 seconds (78.86% PHP - 21.14% MySQL) with 10 queries
