B200 Kef Drivers - Page 3 - diyAudio
Old 26th January 2012, 02:14 PM   #21
Question SP1054
Hi everybody!
My name is Michele and I come form nord Italy.
This is my first post in this forum (i think) but i want to say that this forum is great! I've been signed since some years ago and in this place I've always found lots of intersting topics.
I need your help.
I own a pair of KEF SP1054. What do you think about its sound? And there is the crossover network of KEF Calinda speakers which mounted SP1054: Crossover for Calinda. What is this configuration? Why the 5uF cap doens't stay after the 3.29mH coil, in parallel with the woofer to make a 2nd order low pass filter?
Thankyouuuuu!
Miki
Old 26th January 2012, 02:30 PM   #22
Ouroboros's Avatar
The low-pass filter for the B200 in the schematic is a modified version of a 3rd-order 'T' type network, so there will be an inductor between the 5uf cap and the drive unit. The modification to the 'T' network is the added damped parallel-resonant trap in the input arm of the 'T'.
Old 1st February 2012, 11:42 AM   #23
Ok, that's great! Thankyou! Simulated with MultiSim and I've found a very low crossover frequency (I don't remember, maybe about 250Hz). Any other info about those speakers?
My Sp1054 are mounted in a 18l bass reflex box tuned at 45Hz. I found them good except for the weak bass, but I'm not an expert...
Old 2nd February 2012, 08:30 AM   #24
system7 is offline system7  United Kingdom
system7's Avatar
The original KEF Calinda was a reflex (Well, ABR) design in a 45L box.
Here are the main T-S parameters for a KEF B200 SP1054 (large magnet, low Q) 8" bextrene bass/mid:
Vas 130L
Qm 3.27
Qe 0.25
Qts 0.23
Le 0.45mH
Re 7.0R
Fs 25Hz
TL Links
Back of a beermat, I got 18L as a good size for a closed box with F3 at 75Hz. KEF recommend 20-25L. Reflex, well, this is not so good for you at 18L. You need a bigger box for any real bass. 40-50L.
The shunt first bass crossover is unusual these days, especially since series first needs a smaller inductor. The tweeter is on a standard third order butterworth by the look of it. Probably around 2.5 to 3KHz depending on the impedance of the (7 ohm?) tweeter. The LCR trap on the bass is to tame cone breakup on the B200 around 2KHz. The smaller tweaks on the tweeter probably just equalise it a bit.
Old 2nd February 2012, 09:00 AM   #25
frugal-phile(tm)
planet10's Avatar
Typically KEF XOed the T27 at 3.5 kHz.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 2nd February 2012, 09:26 AM   #26
system7's Avatar
dave
Quite right. KEF speakers with all their equalisation for smoothness also often had strangely huge peaks in impedance. I think the Calinda peaked at 60 ohms around 1-2 KHz. Michelino, your modded 18L unit probably has huge cone movement at low frequencies, which is not ideal.
A review I read had a huge dip in frequency response at 3Khz too. You'd think the tweeter was better wired the other way for phase alignment, but since the woofer and tweeter centres are nearly a wavelength apart at this frequency, effects would be unpredictable.
My own experience of bextrene bass/mid units is when they got hot at parties, they turned to jelly. Dull sounding too.
8" bass and 1" tweeter is just about as bad as it gets to have good midrange phase alignment and dispersion, but of course, easy to implement. Cries out for a midrange unit really!
Old 5th February 2012, 06:26 PM   #27
Thankyou everybody
So... I've just re-simulated the calinda xover but I've found 250Hz @ -3db ... What's wrong? See the picture http://s17.postimage.org/xyvdf8qr3/sim_calinda.jpg .
About my speakers:
The sp1054 are in an 18 liters vented box tuned @45Hz in serie with a 0.5mH coil (cutoff should be at 2.3kHz) and a Zobel network (C=6.7uF, R=15Ohm, not really optimal value).
The tweeter is a Ciare ct 200 with a 2nd order high pass at 1.8kHz ....
Ok, there is something wrong with the frenquency of low pass filter, I actually don't have a bigger inductance
My amp is a modded NAD 304 ( swapped a lot of capacitor, even signal capacitor with polypropylene caps) and at high volume I found no big excursion but it puts out "only" 35+35w.
I've got a panasonic wm-61a mic and an Emu 0204 usb soundcard. Is there any free sotfware for some spectrum measurement?
Old 5th February 2012, 07:25 PM   #28
system7's Avatar
Looks to me like that crossover schematic is plain wrong. Try L2 = 0.6mH in your simulation and see where -3dB goes. We're looking for about 3KHz crossover here.
I made the B200 Zobel: Capacitor C = 5.88 uF Resistor Rc = 8.75 Ohms
You knew that already.
Old 6th February 2012, 03:18 AM   #29
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
system7:
..Looks to me like that crossover schematic is plain wrong...
Agree.. FYI:
b
Old 6th February 2012, 03:20 AM   #30
speakerman19422's Avatar
High qts. drivers have their limitations compared to low qts. drivers. Search this forum for transmission lines and much insight can be found. IPL Acoustics has used drivers with qts. of higher then generally accepted. I have also tried higher qts. drivers. Drivers meant for base reflex have a higher F ratio [fs/Qts.] compared to closed box drivers.
SEAS DRIVE UNITS
IPL ACOUSTICS**** TRANSMISSION LINE KITS
0 Phase Constant Voltage Series Crossovers.
1/4 W T-lines for Satellites and Subwoofers
KEF B200 Sp1039 wightie Multi-Way 16 7th September 2012 07:28 AM
KEF B200 drivers pshead Multi-Way 19 11th April 2010 04:27 PM
wtb (1) Visaton b200 nvrgdenuf Swap Meet 1 17th February 2010 04:46 PM
Tangent TM1 replacement drivers-- B200? B110? drec Multi-Way 2 19th May 2008 07:32 PM
Kef B200 SP1014 Drivers Lad Multi-Way 1 13th August 2007 08:05 PM
Copyright 1999-2017 diyAudio
