B200 Kef Drivers
B200 Kef Drivers
Old 2nd April 2013, 10:10 PM   #111
system7 is offline system7  United Kingdom
system7's Avatar
Vas about 50 litres.
Qts about 0.4.
Hope it helps.
Best Regards from Steve in Portsmouth, UK.
Old 27th April 2015, 06:37 AM   #112
rafbraw is offline rafbraw  Poland
Hi all
I need the specs of KEF Type SP1092 speaker coming from CODA III B200 unit. Actually I am looking for replacement as the coil started rubbing the magnet. Except of that speakers sound still great at high levels. Wondering what could be a cause... maybe rust (?)
Many thanks
Raf
Old 27th April 2015, 09:52 AM   #113
system7's Avatar
Take out the offending bass unit, mark the upside of the magnet with an indelible marker, then turn it 90 degrees. Usually fixes it. The spider and surround sags, I expect.
I don't know for sure who made the paper bass, possibly Elac, but it's a common model found in a lot of old designs. Like the Monitor Audio R352.
I'd think this will work well enough as a replacement:
80W 8in Shielded Bass Mid Range Speaker | Maplin
I'd need to see the crossover to suggest any more. But you can adjust tweeter level with a ceramic resistor or two.
Old 27th April 2015, 10:03 AM   #114
It looks like I found the issue You can see little bubbles of air inside of paper tube.. however the coil is in good condition. I think the speaker was overload.
Old 27th April 2015, 01:15 PM   #115
That's great. Thank you for response Steve...
B200 Kef DriversHide this!Advertise here!
KEF B200 Sp1039 wightie Multi-Way 16 7th September 2012 06:28 AM
KEF B200 drivers pshead Multi-Way 19 11th April 2010 03:27 PM
wtb (1) Visaton b200 nvrgdenuf Swap Meet 1 17th February 2010 03:46 PM
Tangent TM1 replacement drivers-- B200? B110? drec Multi-Way 2 19th May 2008 06:32 PM
Kef B200 SP1014 Drivers Lad Multi-Way 1 13th August 2007 07:05 PM
