B200 Kef Drivers
B200 Kef Drivers
Old 6th March 2012, 06:53 AM   #101
Ouroboros is offline Ouroboros  England
Ouroboros's Avatar
Ferrofluid lasting 30 years?
In my experience with Audax tweeters, particularly the TWO25A1 (A TWO25A0 with added ferrofluid), then after 15 years or so the fluid has dried out a lot. I've converted more than one old TWO25A1 to the A0 version by laboriously cleaning the remains of the ferrofluid off the coil, and then using blotting paper and a fine needle to remove the rest out of the pole piece gap.
Old 6th March 2012, 08:02 AM   #102
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
B200 Kef Drivers
Depends how hard the system is run. I've had to replace ferrofluid in three year old compression drivers.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 6th March 2012, 07:43 PM   #103
speakerman19422 is offline speakerman19422  United States
speakerman19422's Avatar
The question was asked on another forum about ferrofluid. Read post 21.
It really all depends on the many factors involved.
ferrofluid cooled tweeters.... - Page 2 - AudioKarma.org Home Audio Stereo Discussion Forums
0 Phase Constant Voltage Series Crossovers.
1/4 W T-lines for Satellites and Subwoofers
Old 1st April 2012, 05:35 PM   #104
michelino is offline michelino  Italy
Good evening!!
I'm back with some news....
http://s13.postimage.org/8ohg4ubyv/2...4_00_23_57.jpg
In few words, the sound is now far better than before: the xt19 is an awesome tweeter and with the BSC there is more punch from the SP1054. More detail, realism, better soundstage, flatter response and more natural sound than my previous setup.
I had no time to tweak crossovers up to now. This is the actual circuit:
Click the image to open in full size.The only thing I have done is to cut the port to have a tuning freq. of 45-50Hz.
This is the actual response, measured with emu 0204 and home made micro (the famous panasonic wm-61a):
woofer response:
tweeter response:
All the measurements have beend done in my room at a distance of 60cm (about 25 inch) on the tweeter axis.
What do you think about it?
Old 1st April 2012, 06:29 PM   #105
system7 is offline system7  United Kingdom
system7's Avatar
Originally Posted by michelino View Post
...snip...
Amazing, Michelino! So impressed! Just to remind everyone. Michelino is using the ancient KEF B200 SP1054 plastic 8" bass/mid in a smallish reflex box around 28L with the 4 ohm Vifa XT19 tweeter that everyone likes so much:
Vas 130L
Qm 3.27
Qe 0.25
Qts 0.23
Le 0.45mH
Re 7.0R
Fs 25Hz
Effective 3rd. order crossover around 2.5kHz, because he's using the 0.45mH woofer inductance as the second crossover coil element and the bafflestep resistance modifies the coil and capacitor values as below.
LC Filter Design
The KEF takes advantage of better modern tweeters and a lower crossover point! Plus some time delay compensation...the icing on the cake! Very well done, my friend. A minor masterpiece.
Best Regards from Steve in Portsmouth, UK.
Last edited by system7; 1st April 2012 at 06:47 PM. Reason: Corrected box size...ooh, that's the same as mine! LOL
Old 1st April 2012, 09:12 PM   #106
vinyl dragon is offline vinyl dragon  United Kingdom
Really love the time delay design, they remind me of the classic Leaks from the 70's (always wanted a pair) but I'm being dead thick here what's the circuit design of? I can't make head nor tail of it!
All the best
Old 1st April 2012, 10:06 PM   #107
system7's Avatar
All the best
It's the lowpass circuit which is, IMO, clever. It uses a RL Bafflestep Compensation Circuit as an input resistance.
This gives you a 3rd. order 2500Hz Butterworth on the bass/mid in effect, but the component values get modified so the coils are the same size:
LC Filter Design
This is different from the standard calculation:
2-Way Crossover Designer / Calculator
Butterworth filters have a pleasingly flat impedance, and the input resistance should give a valvey sound and an easy load.
File Type: jpg 3rd_order_butterworth_lowpass_2500Hz.JPG (29.4 KB, 31 views)
File Type: jpg 3rd_order_butterworth_highpass_2500Hz.JPG (37.0 KB, 34 views)
Old 8th April 2012, 09:32 AM   #108
Good morning and Good Easter!
Yeah, I'm satisfied about my new speakers, Steve ... Thankyou so much!
But, I'm not so expert so tell me... what did I do of so special? I've played with LSPCAD and then realized the design... The high pass is a Butterworth filter @2,8kHz, the lowpass even a butterworth but with the BSC.... Then 20mm of buffle thickness and that is ...
Ok, I've undestood. That's a trick in that LC filter calculation you suggested... but I've not undestood what is that trick ... are there some more infos on the web?
Last 2 things: 28liters of box is not enough. 80Hz of -3dB frequency is not enough I think. And... The about XT19 resoponse... How can I make it flatter?
Old 8th April 2012, 02:31 PM   #109
system7's Avatar
Good afternoon, my friend. Christ has risen a little later in Portsmouth.
What you've done is apply an elegant result which fits a filter exactly to a particular bass unit. Here, a B200 SP1054 with a Re of 7 ohms, Le 0.45mH.
Applying Le/Cz=49 (Re squared), we get a Zobel capacitor of 9.187uF. This in series with 7 ohms will theoretically flatten the impedance of the bass unit, but we're not doing that. It just remains to calculate the resonant frequency for those values of Le and Cz and 14 ohms as a series LCR circuit, which here is 2476 Hz.
Alan Yates' Laboratory - VK2ZAY's Engineering Calculators - LCR Resonance
It's my notion that it is a VERY GOOD THING to use matched source/load filters with transistor amplifiers, because they have very nice impedance which should give a warm sound equivalent to valve amplification.
LC Filter Design
You now can use the bass unit's voicecoil inductance as a filter component, the 7 ohm input resistor in parallel with a coil to do 6dB bafflestep correction, and it all works out well. To be fussy, you should do the same with the highpass tweeter filter, which will flatten overall impedance, but I'll forgive you here.
To boost bass, you could modify your R1 value to 7 ohms. I would L-pad the tweeter too, to get it to roughly 7 ohms. The Vifa XT19 is an uncomfortably low 2.9 ohms Re, and that really needs raising. To consider for your next effort anyway!
Old 2nd April 2013, 05:49 PM   #110
Baldin is offline Baldin  Denmark
Baldin's Avatar
Send a message via MSN to Baldin
Default Thiele Small parameters
Originally Posted by MykhailoM View Post
Hi Sure I came across this sp 1193 drivers. I have KEF CARA 1985 2-way speaker which I would like to MODIFY to better sounding speakers wit the tweeter and Mid/Bass drivers preserved.
Old thread ... but I'll try anyway
Just got myself the bass drivers from a Cara ... all 4 units for less than 15 Euro!!
Couldnīt resist the offer
Does anyone have some Thiele Small parameters for these??
Bass SP-1193 and Passive SP-1185
Was thinking of making a small sub for my PC or something, maybe using the two active woofers in iso-baric and adding some weight to the passive to lower resonance ......
Thanks in advance Baldin
Visit www.sensibleaudio.dk or read latest news on Baldin's Blog
B200 Kef DriversHide this!Advertise here!
KEF B200 Sp1039 wightie Multi-Way 16 7th September 2012 06:28 AM
KEF B200 drivers pshead Multi-Way 19 11th April 2010 03:27 PM
wtb (1) Visaton b200 nvrgdenuf Swap Meet 1 17th February 2010 03:46 PM
Tangent TM1 replacement drivers-- B200? B110? drec Multi-Way 2 19th May 2008 06:32 PM
Kef B200 SP1014 Drivers Lad Multi-Way 1 13th August 2007 07:05 PM
