I have a pair of Vifa P11WH-00-08 midbass drivers. Apart from the Vifa recommended enclosure sizes for this driver, I think better bass is achievable as they have favorable specs:
52-6000Hz Fs 52Hz Qts .21 large magnets 415g currently they are in a 5L box tuned at 95hz, this seems pretty high seeing how low this woofer can go, what would you suggest I do if I want to get the most bass possible while still keeping it at bookshelf size? Thanks |
#2 |
I wouldn't expect to get a great deal of bass out of these. Running out of Xmax is going to one of the main problems. Looks like they are tuned to give a peaky mid bass response
You could always tune to 70Hz using a 39mm x 99 long port to flatten the response a bit and see how it goes or extend the existing port with a carboard tube or PVC pipe as an experiment. |
#3 |
they have a 3mm Xmax which isn't too bad for such a small woofer, I am also willing to up the box size if necessary, thanks for your reply 70Hz would be a big improvement, how did you come up with that measurement?
#4 |
If you want bass...
what about a mini-TL? Of course you´d have to give up on some SPL but well that also depends on taste and what you´ll use them for. I´ve TL´s with 6.5" that also have 3mm-xmax and that´s plenty for my listening room. I´m no expert at this but could try to put your TS-parameters(if you´d post them) in Martin´s worksheets and see what they can do.
jens |
#5 |
I had considered a TL but have had no experience building those. Where are Martin's sheets? Here are further TS parameters:
rms power: 30W dc resistance: 5.4ohm Vas: 10.3L sens: 88db Thanks |
#6 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#7 |
Assuming the specs are ~accurate, with an 8ohm series resistor it sims max flat in 10.29L/51.5Hz, so F3 should be around 45Hz. Since it's only rated 30W, it just barely runs out of Xmax and peaks at ~100dB/half space. Short of a huge back horn, this is about as good as it gets and still be able to use its wide BW.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#8 |
so you are saying I could tune this woofer down to 45Hz in a ported enclosure? That would be pretty cool, but I would need a box close to the VAS in size? Would like to know more if you are willing to offer further information. Thanks in advance GM
#9 | |
Someone correct me if I'm wrong, but if you increase the box volume you also increase the cone excursion (which can then run out of Xmax) and reduce the speaker efficiency. I got my figures from LSPCad but I suggest you get a copy of WinISD and play around. I'm not trying to put you off but trying to let you know there will not be bags of bass and you could run into cone excursion limitation. Experiment and have fun. Just try retuning the port first (making it longer) with a cardboard tube. |
#10 | |
Fd = 52 Hz Re = 13.4 ohms lvc = 0.38 mH BL = 5.4597 n/a Sd = 58cm^2 Vd = 10L Qed = 0.645 Qmd = 1.1 (it will calculate Qtd) L = 30.38" zdriver = 10.81" zport = 15" SO/SL = 26.736"^2 density = 0.2lbs/ft^3 rp = 0.75" Lp = 4" GM
| "Vifa PL11WH09-08 Premium Line Paper cone midrange" | GOWA | Multi-Way | 0 | 17th November 2007 01:22 PM |
| ACI 12" sub drivers (2), Vifa 8" poly (4), North Creek D26 tweeters (2) | nodiak | Swap Meet | 2 | 29th October 2007 03:45 AM |
| AudioXpress August 2006 - "Equalize the Bass Response of Your Room" | ergo | Multi-Way | 0 | 12th April 2007 07:35 PM |
| 10" basS/mid for "party-speaker" | TroelsM | Multi-Way | 0 | 16th September 2005 11:14 PM |
| cheap 6" or 8" woofer to make great bass for a standard cab pick up | zuki | Subwoofers | 12 | 15th February 2005 07:54 AM |
| Page generated in 0.11253 seconds (80.42% PHP - 19.58% MySQL) with 10 queries |
