I am looking for a good 6-8" mid that will run IB in my car door. 3-1/4" mounting depth max. Something in the $50-70 range, I'm not sure yet what to get. I want it to sound detailed (I like paper cones) and 'flat' sounding. I guess I'm looking for a Dynaudio type of sound without the Dynaudio price.
I have Vifa tweeters D25AC-07-06 that I got from Ebay. Also A/D/S/ crossovers from a car audio component set (don't know crossover frequency, probably 3-4khz) 4 or 8 ohms is fine so home drivers are ok. They will get aprox. 150 watts. A couple options I have so far, Vifa PL, Peerless HDS. I want to use a diy driver like these but it's hard to find reviews on them and there's nowhere to hear them. |
#2 |
Probably would place my bet on the HDS series.
#3 |
Keep in mind that the Peerless HDS mids have a very exposed voice coil, and I wouldn't recommend them for car door use on that basis alone.
You'll also need a nitch filter to take care of the spike around 1-1.5k thats' prevailant in nearly every door mounted mid. |
#4 |
I recommend the Silverflutes at the very bottom of the page- 4 or 8 ohm.
http://www.madisound.com/silverflute.pdf |
#5 |
I would recommend the Morel MW164. You can get them in 4ohm as well, if needed, from Madisound. They have a 3" Hexatech VC just like Dynaudios, and and are not overpriced IMO. I built a component set for my car with MW168s (a bit lower Q than the 164) with the Vifa D26 tweeter. I am really enjoying them.
#6 | |
Thanks for the suggestions, I may go with the Morels based on reputation. I haven't heard of Silverflute before.
#7 |
about that spike, if your use sounddeadner, i doubt its a problem.
| ISOBARIC 16 ohms load powered by 8 ohms Amp | eddi0 | Subwoofers | 24 | 21st October 2006 03:29 PM |
| Seas Excel mids vs. dayton rs mids in dipole | sqlkev | Multi-Way | 2 | 10th July 2006 06:28 PM |
| Speakers: 8 ohms vs. 16 ohms | KT | Multi-Way | 2 | 14th April 2006 05:06 PM |
| Lil mids help | Radik | Multi-Way | 1 | 28th July 2003 01:21 AM |
| mids | Kilowatt | Multi-Way | 3 | 17th January 2002 01:10 PM |
| Page generated in 0.09683 seconds (78.27% PHP - 21.73% MySQL) with 10 queries |
