Old 15th August 2004, 10:58 PM   #1
Send a message via AIM to bhg41088 Send a message via MSN to bhg41088 Send a message via Yahoo to bhg41088
Default Eros
How would an Eros Clone using 2 of These and using the same Scan Speak D2905/9500 tweeter that Wayne uses. I would wire the 4 ohm PL's in series and use the same crossoverover, but ajusted for 8 ohms. Would this result in good/bad results?
Old 16th August 2004, 12:48 AM   #2
wigginjs's Avatar
Since I'm pretty sure no one has built it there isn't any really good way to tell. You could simulate it, but real results would come from building it. I would build it and if it sounds bad just buy the drivers Wayne uses and pop them in instead. Either way you end up with a fantastic pair of speakers.
The Four Chairs
DIY Home Theater
Eros loudspeaker potepuh Swap Meet 0 23rd April 2006 07:55 PM
Eros Tweeter?! Wyloch Multi-Way 2 6th June 2005 12:31 AM
8 ohm Eros? spots25 Multi-Way 4 12th January 2005 05:49 PM
Eros with different crossovers. rs1026 Multi-Way 7 9th December 2004 05:31 PM
Anyone here build the VSS Eros? jwv3 Multi-Way 4 18th March 2002 10:31 PM
Page generated in 0.07137 seconds (65.94% PHP - 34.06% MySQL) with 10 queries
