pa sub sat system
pa sub sat system
Old 17th August 2004, 01:58 PM   #21
johninCR is offline johninCR  United States
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
Greg, the maelstrom is a nice hybrid sub. It's got 93db of sensitivity and quite musical. It's advantage would be in cab size because the pro sound woofers need vented to get flat down into the 50's and require a minimum cab size of 3 cubic ft. The maelstrom only needs 1.5 cubic ft sealed to do the same. However, Holger doesn't have alot of power to work with, so an extra 3-5db of sensitivity might be necessary.
Paul is right on the money regarding the use of sonotube. That will give you the lightest possible cab(s). I don't know about bandpass though; bigger cabs; hard to get right; and no sensitivity gain with the wider bandwidth required.
Here's another idea for a lightweight rig with really sweet sound. Dipole tops with a couple of U Baffle bass units using sonotubes. Boxless could be great depending upon how the rig will be used. Plus it would be the lightest way to go.
Everyone has a photographic memory. It's just that most are out of film.
Old 18th August 2004, 12:10 AM   #22
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
pa sub sat system
These would work well in the Hurricane setup with the Maelstrom
woofers
http://www.partsexpress.com/pe/pshow...18&ctab=2#Tabs
The Radians seem to be very highly regarded. Yes they are pricier than the Adire 8" coax's but I'll bet they sound better too.
So the Radians at $600/ pr and the maelsstroms at 600/pr
arouund 1200 for drivers
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 18th August 2004, 06:44 AM   #23
paulspencer is offline paulspencer  Australia
paulspencer's Avatar
Depends on the bandwidth. I see no problem with covering 50 - 100 Hz with a bandpass. I've seen a number of bandpass boxes used in PA quite well. The lightest and smallest is a Bose unit that can be easily carried by one person. It uses a 12" sub driver that looks very similar to a hifi sub driver.
Rather than cross high as Holger was originally thinking, it makes more sense to me to cross at ~ 100 Hz and use a steep slope in the active crossover. To get efficiency in the bass, you need either horn loaded or bandpass, and both have a limited bandwidth, added to the other issues already mentioned with a higher crossover point.
Regarding matters of size, weight, efficiency and bandwidth, a quick look at Bills site suggests he has a good system.
Interesting idea. I have heard of dipoles being used for PA - the dipole null to the sides can be used well regarding feedback, and the sound radiated to the rear can be quite useful as well. Then there is the lack of coloration.
U baffle bass sounds promising. If you look at the Nao design, although hifi, it is 2 ft deep with 12" hifi sub drivers and bass extends to about 50 Hz if I remeber correctly. In terms of output it is equivalent to a sealed box wth a bit less extension but less excursion control. Although a setup like this could be made out of lightweight modules, I can see you would need to build it up in modules to get decent output. You would probably need to look at high pass filters to deal with this. The benefit of such a bass design would be very natural uncoloured bass but the tradeoff is efficiency, power handling and output.
Old 18th August 2004, 03:38 PM   #24
holger honda is offline holger honda  United States
Default bandpass.
I have seen alot of bandpass subs in pro sound applications. I dont have a problem with the "one note" syndrome as long as the one note is loud and comes from as smallish box
thanks for reading.
H.Honda Chico CA Land of the fooled
Old 19th August 2004, 11:30 AM   #25
I went into a "hifi" shop today and they had this tiny little sub, not sure if it was vented or sealed but it was one of those crappy boom boxes with a hideous sound! One note definately ... but I've heard a lot of bandpass PA subs that were quite decent. Usually with rock music at some live event, where it doesn't seem to matter that it's not refined and subtle.
What kind of output are you looking for? Do you have an idea of what SPL level at what distance and what type of location / venue?
Old 20th August 2004, 07:39 AM   #26
Default magnum seems doeable
Hello.
I checked with someone who claimed one could make a "sub" using a eminence magnum 15HO in a 2.2 cubic foot vented box.
Thats a big thing in a small box,wich probably will pack some punch. The way to do this was using a 6 inch tube as long as 11 inches...thats a ******* pipeline.It would start rolling off at the high frequency of 60hz.Maybe a bad idea,but it is small and portable.Wold feel much better if it could play down to 50 and then start rollling off.
thanks for reading.
Old 20th August 2004, 08:23 AM   #27
diyAudio Editor
Variac's Avatar
pa sub sat system
MAybe one could have folding panels for the highs-
They would be like folding screen room dividers-say maybe 3 panels 18" wide and 5' high with a removeable say 8" or 10 " coaxial driver. This should go down to 100 hz, right?
One could just unfold the screen with the side panels back at about a 30 degree angle and attach the driver with wingnuts to an opening in the middle panel. I don't think the driver needs extra x max if the panel is big enough and there is a high pass crossover. It could be placed on top of a large sub box to make it bigger and taller, but smaller sub cubes would be easier to transport.
pa sub sat systemHide this!Advertise here!
What's your system looking like right now? jduffy Chip Amps 1 5th May 2008 08:38 AM
Help with PSU for Tri-Amp System snax Power Supplies 9 16th July 2007 08:17 PM
Dj System GOWA Multi-Way 5 6th July 2007 03:57 PM
Keep RFI out of your system? I_Forgot Everything Else 3 5th July 2007 02:34 AM
PIC Of My system in the car Dj BASS AMP Car Audio 10 10th January 2004 10:38 AM
