Old 13th August 2004, 12:36 PM   #1
foo is offline foo  Tibet
Default Eton or Accuton or ???
got 2 Idea
1.c12-2 + Eton 5-880 MTM setup
2.c12-2 + 7" Accuton single midwoofer
which one do u prefer ? And Why ?
I found the midbass can't fit with the tweeter perfectly because it has a little lower efficiency between 1khz and 4khz .
Does that reduce it's performance a lot ?
Or should I forget these 2 idea and go for an Audiotechnology
midwoofer ?
Old 13th August 2004, 01:36 PM   #2
Taco is offline Taco  Netherlands
What for sound do you like?
I think the c12 + 7" has more potential. Eton is very nice but the accuton has better top-end.
If you like very smooth details without any grain buy an AudioTechnology C-quenze 7" and combine that with a Morel MDT-33 / Supreme 110 or something from ScanSpeak.
The Accuton /Thiel has a better defined low-end, but the mids of the AT are very very good.
Motorsystem of AT is huge, below a picture of a 15cm c-quenze unit (also used by Sonusfaber and Eben).
Old 13th August 2004, 01:44 PM   #3
Pan is offline Pan  Sweden
With the 7" just pad down the tweet with resitors.
Anyway, you canīt use the top end sensitivity ofthe 7" as the target anyway... unless you put the speaker up against a wall or prefer thin sound without body.
In a typicall box the 7" will have 83-85dB in the low mids and thatīs what you have to aim for with the tweeter as well.
Using two drivers parallell you have higher voltage sensitivity (like 90dB with Etons) but lower impedance which will draw more current from the amp.
/Peter
Old 14th August 2004, 10:27 AM   #4
Thx for ur advices guys
especially the tweeter advice
i found out it's much easier to use the scan 9700 combined with eton 5-880 MTM setup
guess it will be my last design
Old 14th August 2004, 02:02 PM   #5
i also found the scan 8531G is good in a closed enclosure
much better than the 5-880s
But ...
Weeeeeeee~~
It's expensive ....
Accuton C92-6+ETON ER4 project Alex_J Multi-Way 9 6th October 2006 05:21 PM
accuton and eton prices ermes Multi-Way 2 4th December 2005 07:49 AM
Help with crossover for Accuton and Eton? guru Multi-Way 1 8th August 2004 10:08 AM
ACCUTON (THIEL) or ETON Kal Multi-Way 16 27th July 2004 07:35 PM
3-way Eton/Accuton TL question Jan Deckers Multi-Way 0 27th May 2004 07:41 AM
Page generated in 0.09605 seconds (76.01% PHP - 23.99% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
