Old 12th August 2004, 05:38 PM   #1
Default Tangband 871 and what to do with them
I've been looking around on the net for what to do with the tangband 871s, there seem to be a lot of designs out there using them it's getting hard to choose one.
Is there any concensus how someone can really get the most out of them, with this I'm referring to the following things :
- What is the best cabinet : bassreflex, closed, tl, ob, ...
- Filtered or unfiltered like ELF 1.5
- Together with another tb driver like in the superELF
- How good is the 657sc compared to the 871s as these also look nice
- are the designs for the ELF 1.5 or superELF publicly available
- ... (any tips or experiences are "very" welcome)
My plan so far is :
To use 2 871s's per speaker in a bassreflex cabinet without any filtering and placing the two drivers together as close as possible to minimize combing. I think it would be safe to cross them to a subwoofer at 100Hz (don't know for sure though)
Old 12th August 2004, 05:48 PM   #2
http://home.new.rr.com/zaph/audio/audio-speaker11.html
Old 12th August 2004, 06:28 PM   #3
Yep encountered them on the net allready and they look good but I've got my doubts about them going loud enough for me. It's not the "going loud" that's so important but having just that little bit of reserve is never bad to have.
Old 12th August 2004, 10:30 PM   #4
Send a message via AIM to bhg41088 Send a message via MSN to bhg41088 Send a message via Yahoo to bhg41088
You should run some Bi-polars using Johns design back to back. Someone had a link to there project using 2 BR-1s back to back. Pretty cool. ohh, and wire them in series and toss a 150hz high pass on them. They have been blown with 1 watt at low frequencies. Also you should use 2 subs, one next to each Front speaker to prevent sub localization with that high crossover.
Old 13th August 2004, 05:51 AM   #5
Timn8ter's Avatar
Check out this thread. I agree that a bipole push push TL would work well and give reasonable SPL.
TQWT for the TB W3-871S
BIB with 2 tangband w4-657? Mayday Full Range 2 23rd April 2007 10:53 AM
help... please....Tangband W3-871 yepper Full Range 4 17th December 2004 04:06 AM
Tangband in the UK Kram Full Range 9 29th November 2004 10:37 PM
Tangband W3-871 .Can I...? Lito Full Range 4 8th June 2004 04:32 AM
Anyone ever tried a tangband TL? JoeBob Multi-Way 2 30th March 2003 03:03 AM
Page generated in 0.06714 seconds (85.14% PHP - 14.86% MySQL) with 10 queries
