Hey guys, I was wondering if I could get some help choosing a speaker set. Here are the details....
I intend to use it primarily for music with: - my laptop, wihch is a Dell Inspiron 5150 with SigmaTel Sound Card (supports 5.1) - my iRivier mp3 player and to a lesser extent movies and sports my DVD player and TV. Since I'm in a dorm and can't really crank the bass, the high end power of the sub isn't a big concern to me. I guess I'm mostly concerned about the quality fo the midrange for all around musical enjoyment. After all rebates and including s&h, the Logitech system is $111.04 and the Klipsch is $179.88. Is the Klipsch worth the extra $70? How is thie choice affected by my stock dell soundcard? I read something that the Klipsch speakers will only play in 5.1 if you have a "DIRECT digital connection." Can I solve that problem by purchasing this (http://store.mrtechus.com/so51usb.html), which has an S/PDIF interface? Yours, Jack |
#2 |
The Klipsch GMXs are the more accurate of the two with its discrete tweeter. It doesn't accept analog surround inputs, just analog 2.1. And even if you have digital outputs on your soundcard, you'll only get surround sound with Dolby Digital content (or sound encoded to DD courtesy of the NVIDIA nForce2 Soundstorm APU for Athlon XPs). That is, if you don't have that chipset, games are played in 2-channel mirrored to the rear. In short, if you play games, don't get this system. For DVD, it should be fine.
The Logitechs are a very good midrange system but the speakers are hardwired (no replacing the cables). The Klipsch uses removable RCA cables for connections. For music, the Klipsch I think is the better pick. For movies, either will do.
KTK. Kool To the Kore. |
#3 | ||
Listen to the music through the stereo, not the stereo through the music. |
#4 |
hey guys -
thanks for your responses. it helped me understand the problem with 5.1 output with my current laptop soundcard. after thinking about it, i watch DVDs on my DVD player, so I don't really need 5.1 output from my laptop anyway. i understand that both speaker sets would work well with my dvd player. this leads me to two additional questions - 1) fenris, you're right, the dell only has a stereo headphone output. am i correct in understanding that if I plug the klipsch or logitech into that, i will get 2.1 channel sound from the four satellite speakers and the sub? (sidenote: what would the center speaker do?) if all my music is recorded on two channels, than 5.1 output doesn't do anything for me, right? (assuming this to be correct, i would use it as 5 speaker 2.1 channel system with my laptop/iriver, and 5.1 with my dvd player) 2) my iRiver iHP-120 also has an optical line out in addition to a headphone stereo out . what can I do with the optical line out? would that have any advantages over plugging the system into the headphone stereo out? - jack |
#5 | |
#6 |
The logitech system has a more power subwoofer..
But then you said thats kinda pointless for you.. I would go for the Logitechs because they are cheaper. But go to the store and bring your Iriver, try testing out both sets and see which sounds better to you. |
#7 |
What about the Promedia 2.1s? Personally I like the styling better than GMX's. Best Buy says they sell them for $150, and you could probably find them cheaper through an internet vendor. I personally have the Ultra 5.1s which I really like. A friend of mine has the 2.1s which he enjoys. And if you ever did want more bass, that little sub they give puts out a good bit, but can be turned down of course. You can always go to a Best Buy, Circuit City, whatever, and try them out. They usually have them set up to listen to. Although it won't be an ideal setting, at least the arrangement will be consistent enough to allow you to compare the two side-by-side.
#8 |
If you want the better sounding set, go with the Tangband based Logitech system. They do sound better. I A/B'ed them at a local BestBuy and could hear a dip in responce that sounded like a poor crossover (or none at all ) in the Klipsch. The Logi's just sounded better, especialy vocals.
#9 | |
The crossover is a minimal one, but make no mistake: there must be a crossover. We're not talking about piezos here but rather horns.
#10 |
Thanks guys, your replies have been extremely helpful. I decided to get the Logi 5300's off Amazon, and they arrived the next day (yesterday, with free shipping). They sound great and I'm really happy with the purchase.
Now, I live in a dorm, so I can't really shake the walls or floor with this sub. Is there anything I could place under the sub to minimize transferring the rumbling to neighbors? - Jack |
| (Hacking the) Logitech Z-5300 pinouts? | superxpro12 | Chip Amps | 2 | 23rd October 2009 03:02 AM |
| Need help with Klipsch 2.1 Promedia Please | mrfix90 | Subwoofers | 0 | 31st March 2009 03:45 AM |
| LOGITECH Z-5300 Without Remote | orexio | Chip Amps | 0 | 4th January 2009 11:44 PM |
| Klipsch Promedia's Died - Upgrade Advice - DIY Options? Minimus 7? Logitech? Partsexp | Mysticle31 | Multi-Way | 3 | 17th August 2008 08:25 PM |
| Logitech Z-5300 satellite driver | TKESlinky | Multi-Way | 3 | 10th September 2005 06:21 PM |
| Page generated in 0.15501 seconds (83.49% PHP - 16.51% MySQL) with 10 queries |
