Old 11th August 2004, 04:47 AM   #1
DayG|o is offline DayG|o  Canada
Default help on home woofer
Hello all i am very new to this board and have ventured into diy this summer.
I read through lots of the post and took the time to look at all the loud speaker pics and i i must say that i was impressed by many things.. so i know im in a good place.
You guys know speakers like i know computers. So i trust i will get some great answers to this.
Here is my ..Q:
I have a subwoofer and although it sounds pretty nice , i think im not getting its full potential. I have 2 cerwin vega LE8D's 150watts rms each. The box i made is HxWxD 22X11X15 with a port centerd in the back , 3" diam. and about 6 inches long.
Since i did that orig. set up i got a 250watt plate amp for it so ill have to do the back pannel again. And im wondering if there is a good design i should be using. Should i have each sub in a seperate chamber, and if so ... how should i do the porting. Also i used foam for a baffle.. it was like 10 bux ... suppose to be a matress for camping or something ..... its in cone shapes .. almost like a egg carton..... seems to work well ..... is this a bad thing to use? There was a definite improvement in sound after adding foam and a port......
The sub is used in HT, id like to get some punch out of it, but .. i get a fair bit from the fronts now. I feel now that the bass is boomie at times. But i do have it very close to the wall.......
Ok enough Q's from me ,i appreciate all the insite you all may have.
-Eric
Custom Home Theater Project in New Home, Opinions appreciated. thadman Multi-Way 5 20th November 2008 12:40 AM
car sub for home madman29 Subwoofers 21 13th November 2006 09:14 PM
Home depot sound insulation material for closed box woofer astarter Multi-Way 0 3rd May 2005 06:37 AM
Home home or pop pop noise from sub ricky fong Multi-Way 0 26th February 2003 01:15 AM
Qts of Push-pull woofer and Compound Woofer System... haggy Multi-Way 1 13th December 2001 01:30 AM
Page generated in 0.06610 seconds (70.65% PHP - 29.35% MySQL) with 10 queries
