Organic Enclosure Shapes: We need to talk.
Old 12th August 2004, 05:51 PM   #21
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
and the baffles used:
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 12th August 2004, 06:18 PM   #22
Bill F. is offline Bill F.  United States
Bill F.'s Avatar
Interesting how well the truncated pyramid measures. And I would have thought the cylinder with driver side-mounted would have measured better than it does...
Old 12th August 2004, 06:21 PM   #23
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
I would expect that almost all shapes would do (much) better with the driver or exitation-hole mounted off-center. Was that addressed by Olson at all?
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 12th August 2004, 06:43 PM   #24
frugal-phile(tm)
planet10's Avatar
Not in this study... he did do some baffle placement studies thou (the one the comes to mind is open baffle).
dave
Old 12th August 2004, 07:14 PM   #25
tiroth is offline tiroth  United States
According to Rod Elliot placing the driver off center reduces the amplitude of some of the ripples but doesn't change the basic character. So, basically, optimize the baffle shape, then make final improvements via placement. Watch out for polar response changes in multiway systems though.
Old 12th August 2004, 07:21 PM   #26
frugal-phile(tm)
planet10's Avatar
Except for exploring off-centre on an open-baffle (where dipole cancellation dominates) Olson doesn't seem to cover off on this subject.
With tools like the Edge or the FRD baffle simulator it would be pretty easy for someone to do a virtual study and give us some baseline. (i'm not doing it -- these tools only work in Windoz)
dave
Old 12th August 2004, 08:34 PM   #27
markp is offline markp  United States
What about the egg? It's good enough for nature, is it good enough for us? How about placing a solid sphere in the center of a spherical cabinet to break up standing waves. Maybe an absorbent ball of fiberglass in the center would be even better.
Personally, I use rings of sonotube about 2" tall of different diameters glue to the larger panels of sub boxes. I lay them out in a random pattern and it makes the 3/4" mdf appear to be several inches thick without the weight. Try it, you'll like it! The sonotube is very rigid along the length and being a tube is self supporting.
If it sounds good... it is good!
Old 13th August 2004, 08:13 AM   #28
Artmaster is offline Artmaster  Ukraine
Artmaster's Avatar
Default nice diagram!
nice diagram! it's realy truth.
it means - form of box is not affect for low end range like 10Hz-100 hz
the same way as damping materials inside.
it's for voice range of wave. it's for 120Hz and higher. another business.
low wave have another biiiig, biiiig problem
Artmaster live in www.artmaydan.org.ua
Old 13th August 2004, 09:41 AM   #29
Mark25 is offline Mark25  United Kingdom
Mark25's Avatar
Diffraction: the ultimate guide.
APPLICATION OF THE GEOMETRIC THEORY OF DIFFRACTION (GTD) TO DIFFRACTION AT THE EDGES OF LOUDSPEAKER BAFFLES, R.M. Bews and M.O.J. Hawksford, JAES, vol.34, no.10, pp.771-779, October 1986
We will pay the price, but we will not count the cost...
Old 13th August 2004, 05:28 PM   #30
That just deals with flat panels of different shapes. We are looking at 3-d shapes.
Organic Enclosure Shapes: We need to talk.Hide this!Advertise here!
visio shapes desmondmonster Tubes / Valves 4 13th January 2009 07:30 PM
Organic Transistors in Hi-Fi ? patch Parts 1 6th December 2007 04:49 PM
Graph shapes Danielb Multi-Way 9 3rd November 2004 12:26 AM
Kemet A700 ALuminum Organic SMT caps? BrianL Parts 3 4th August 2004 08:16 AM
Are you looking for suggestions for enclosure shapes? kneadle Multi-Way 4 2nd March 2003 02:42 PM
Copyright ©1999-2017 diyAudio
