Old 7th August 2004, 08:14 PM   #1
Question Some help with 10" sub design...?
Hello all
Currently, I'm building a pair of 2-way bookshelf speakers with Vifa's TC-line drivers. The bass/midbass is only 5,5" (TC14WG49), so I'm thinking of building later somekind of a sub-woofer to play the lowest frequencies of music.
I planned about buying an 8" Peerless SLS woofer, but then I got this almost unused Focus Acustics 10" woofer from a friend for a cheap price. She didn't have its T/S parameters, so I decided to test it with Speaker workshop:
Qts: 0,735
Qes: 0,826
Qms: 6,658
Fs: 36,50 Hz
Vas: 21,16 liters
Nominal impedance: 4 ohm, single voice coil
The parameters look somewhat strange, is it recommended to mount such a high-Qts woofer into a bass-reflex box? I thought about 50L box tuned to 24 Hz, that combination would make the -3dB point @ 22-24 Hz... I gave also a thought for aperiodic and sealed designs (with similar 50L box), as they would reduce the group delay considerably. What do you think? Perhaps bass-reflex for movies, aperiodic & sealed for music?
Even though you don't actually listen to the _look_ of a woofer, at least for me, it looks very stable and "capable" unit. It has really fat foam surround and quite nicely of Xmax, cast basket and a big magnet. It weighs about 6,6 kilograms. I attached a pic of it...
Old 7th August 2004, 11:59 PM   #2
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
If it's not shielded and has a big magnet, then you should double check those T/S parameters, because a large magnet indicates better cone control at resonance which is the opposite of what a high Qts like .735 indicates.
Everyone has a photographic memory. It's just that most are out of film.
Old 8th August 2004, 12:34 AM   #3
Originally posted by johninCR
If it's not shielded and has a big magnet, then you should because a large magnet indicates better cone control at resonance
Not necessarily.
Old 8th August 2004, 01:16 AM   #4
Originally posted by 454Casull
Not necessarily.
If I've learned something wrong, please provide some examples.
Old 8th August 2004, 01:55 PM   #5
Banned
I also would be very surprised to see a Qts of more than .3 on a driver with that large a magnet structure and that low of a Qms. The 4ohm impedance could mean it's an autosound driver meant for an IB, but then the Qms should be a lot higher. I'd research those specs or measure them yourself before proceeding.
Old 8th August 2004, 03:41 PM   #6
Vigier is offline Vigier  Netherlands
Hey,
the woofer on the picture really looks like a Raveland AXX-1010 woofer, about 55 Euros (say $70)....
Grtz, Joris
P.S. Focus Acustics 10" doesn't ring a bell here... is that sold in europe?
Old 8th August 2004, 04:26 PM   #7
Well, I don't know where my friend got this woofer, but it is most propably automotive subwoofer. She asked 35 euros for it and then it was mine
Perhaps I should test its parameters again, when I've got some time (and a concentrated mind). I don't know where it's sold, nor know it's published parameters (there aren't any?)... I can't even find the manufacturer's website!
The Raveland model looks quite different, in my opinion...
Old 8th August 2004, 09:25 PM   #8
Lightbulb Fixing & testing
Even though it doesn't show in the picture, the woofer's dust cap was pretty much "smashed". So I just carefully removed it and replaced the broken dustcap with a cap from dead JBL GT2 12" woofer. I glued it in place with 2-component super epoxy glue, to ensure it stays in place. Then I painted it with black spray paint.
I did this fix because the broken dustcap made a sound, even in lower sound levels... of course, if it was a 300 euros Scan-Speak woofer, I wouldn't dare to attempt!
However, the cone's mass seem to increased a bit, here are the new parameters from Speaker Workshop:
Fs: 29,8 Hz
Vas: 42,144 L
Qts: 0,617
Qms: 3,617
Qes: 0,743
I did the testing two times, and got almost precisely same results. So, my previous results were wrong, maybe because of wrong added mass during the calculation of Vas.
Seeking advice on "Circlotron" cross-coupled feedback OTL design arteitle Tubes / Valves 8 5th March 2010 09:55 PM
"Box" design and bracing for open baffle woofer array ryoshu Multi-Way 0 17th August 2008 06:07 PM
design help needed: monopole 15" / 8" MTM open baffle with Manger taloyd Multi-Way 26 26th January 2007 10:53 PM
The "Leap-Frog" Method Of Switching Amplifier Control Loop Design analogspiceman Class D 29 1st December 2006 03:21 PM
Need help using "Edge" to design Baffle Step Correction Circuit please. G Multi-Way 5 3rd July 2004 10:49 PM
Page generated in 0.10163 seconds (78.54% PHP - 21.46% MySQL) with 11 queries
