Old 7th August 2004, 04:27 AM   #1
Default Coaxial drivers...
Say you have a 1" tweeter inside a 8" woofer - will the moving 8" cone modulate the sound of the tweeter? I imagine the larger cone swinging 10mm around p-p should do something to the highs coming from the center...
Old 7th August 2004, 05:05 AM   #2
rcavictim's Avatar
Absolutely! The low frequency wavefront emanating from the woofer cone will consist of layers of denser and more rarified air. The speed of sound is faster in denser air than in rarefied air so the sound from the tweeter at shorter wavelengths will get bunched in packets following the low frequency activity. I think you would have to use a two tone generator test to hear the effect though.
I.Q.Test. Have you ever purchased a recreational snowmobile?
Old 7th August 2004, 06:06 AM   #3
But the speed of sound in the air would keep changing, correct? the woofer goes back and forth, and the sound pressure goes down and up...
Would you say that this effect is measurable and/or discernable by ear?
Old 7th August 2004, 07:00 AM   #4
Volenti is offline Volenti  Australia
The only time I've noticed this is when there is a large volume of very low frequencies occuring (typically car audio with bass levels 20-30db louder than the rest of the spectrum), I haven't heard it occur in normal listening levels in a system a balanced frequency response.
Talk into a large desk fan at close range to hear what it sounds like.
Old 7th August 2004, 05:08 PM   #5
I don't think the "talking into the fan" effect is the same, because some sound passes through while much of it bounces off the fan blades...
Old 8th August 2004, 07:30 AM   #6
I have the Adire 10.1s-the woofer cone moves so little I wouldn't think this was a concern-and it certainly doesn't sound like talking into a fan...never has
and then there's the fact that the tweeter is also horn loaded
I'm not sure if this is the line/type of speaker you had in mind but it's the first coaxial(home use) that comes to mind...probably because I have a pair
"The appreciation of music is subjective.The reproduction of music isn't."-Bill Dudleston
Old 8th August 2004, 01:18 PM   #7
I was merely giving an axample of where I've encounted higher frequency sound being noticeably modulated by high levels of lower frequencies, it does sound similar to talking into a fan, and unless he has a system that can reproduce ~20 hz at 130db it's the only way he's going to experience it.
Old 8th August 2004, 02:17 PM   #8
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
If someone runs accross a coax driver that will do 130db at 20hz, please let us know because I want some.
Everyone has a photographic memory. It's just that most are out of film.
Coaxial drivers? Bill F. Multi-Way 54 22nd October 2009 02:23 AM
Using different HF units with coaxial drivers Nuuk Multi-Way 17 30th July 2009 07:15 PM
Coaxial Drivers lejaybo Multi-Way 16 28th January 2009 04:03 PM
coaxial drivers nbcaudio Full Range 4 18th February 2005 06:34 PM
looking for true coaxial drivers. DJNUBZ Multi-Way 11 14th January 2005 04:35 AM
Page generated in 0.09593 seconds (79.10% PHP - 20.90% MySQL) with 10 queries
