#2 |
I have asked the same question myself . I was told the further away from the drivers the better .
Outside of the box is better. On the back In a box of it's own |
#3 |
Yes, if you have the choice, why not outside of the box and for that matter, right next to the speaker terminals of the amplifier, which is meant to be even better.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#4 | |
Not always a good thing to do... I hope the amp is right niext to the speaker involved because having the xover by the amp will decouple the lengths of wire which may deteriorate the sound and hurt the amp as well. If it is, well, you should have no problems. Goodnight Goss |
#5 |
Banned
Make the top, bottom and sides of the box a couple of inches deeper, leaving the back where it is. That will allow you to mount the crossover externally on the back for easy tweaking while remaining invisible from the front and side.
#6 |
Since the center is so huge already I guess a seperate chamber for it is no big deal
Its already got its own shelf under my screen anyhow. Thanks for the tips guys. |
#7 |
![]() I always divide the high pass and low pass sections to separate boards, then mount them on opposite ends of the enclosure. This makes the boards smaller, keeps the coils generally away from the driver magnets when the boards are placed near the back of the enclosure, and keeps the woofer coil(s) away from the tweeter coil(s) to avoid interaction issues. Interesting mounting technique shown above: Make the boards the right length so you can wedge them into the insulation if your insulation type allows for this. In this case, the rear insulation is whispermat, while the sides are .50 carpet pad.
-Zaph|Audio- |
| Need ppi art pcb mount rca jacks | ppia600 | Parts | 1 | 15th October 2007 03:02 AM |
| WT: OPA2604 Surface Mount 2x - Will trade DIP mount 2x | Destroyer OS. | Swap Meet | 1 | 22nd December 2006 06:18 AM |
| how to flush mount | lemans23 | Multi-Way | 7 | 13th August 2005 10:32 PM |
| Mount for snap-in cap | Ed LaFontaine | Parts | 1 | 19th July 2004 02:56 AM |
| How do I mount big capacitors in a box? | swede | Parts | 11 | 12th November 2001 11:57 AM |
| Page generated in 0.09870 seconds (72.07% PHP - 27.93% MySQL) with 10 queries |
