Old 6th August 2004, 10:37 PM   #1
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
Default 2nd Order Xover question
In a basic 2nd order crossover, what happens if I use a different cap value than what is called for? Do I just end up with a stepped xover slope, 6db/oct then 12db/oct ?
Everyone has a photographic memory. It's just that most are out of film.
Old 7th August 2004, 12:03 PM   #2
Svante is offline Svante  Sweden
Svante's Avatar
Either that or a peak in the frequency response, depending on if the value is smaller or bigger. Also the cutoff frequency (which will be a bit hard to define) will move.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 7th August 2004, 01:06 PM   #3
Volenti is offline Volenti  Australia
In my practical experience with passive x-overs, incorrect component values often result in "inbetween" x-over slopes rather then stepped, ie; 9db rather than 12db per oct. It's only when the values are really far out that a step becomes noticable.
I have an older RTA that can electrically measure a passive x-over in circuit, very handy tool.
Old 7th August 2004, 08:34 PM   #4
Svante's Avatar
Yes, of course, the "knees" in the "theoretical" response is just a way to make the physics behind the actual response curve. For example this means that in a 2nd order butterworth filter the slope gradually increases from 0 to 12 dB/oct, it is just in some simplified graphs that there are sharp knees in the response.
Old 8th August 2004, 08:03 PM   #5
Swedish Chef's Avatar
Be sure to use a Zobel compensation network if doing a 2nd order LP. Otherwise you might end up with something else than you intended...
"Knowing what to do but not why is no use in a changing world" - The Art of Sound Reproduction
Old 9th August 2004, 04:13 PM   #6
Kittle is offline Kittle  United States
Like what?
Im trying to keep the # of components in my signal path down to a minimum. and had not planned on using one of them.
(im working on 2nd order xo as well)
Old 10th August 2004, 07:38 AM   #7
Originally posted by Kittle
Like what?
Like a big hump in the response at or just after the intended x-over point, caused by the drivers impedance rising with frequency, a zobel corrects this (as far as the x-over is concerned)
Old 10th August 2004, 08:15 AM   #8
AGGEMAM is offline AGGEMAM  Denmark
AGGEMAM's Avatar
Or instead of a Zobel, you could experiment with a low pass that is 5%-10% lower in frequency than the high pass filter. That will often give the same result, plus the filter slope will be 15/db octave instead of 12/db octave with a 2nd order XO.
Hmm .. no .. I really haven't got anythig cool to say ..
2nd order LR series xover formulae PeteMcK Multi-Way 30 9th June 2007 07:27 AM
deceptive perception ? 1st order-2nd order question poldus Multi-Way 4 10th April 2007 11:58 PM
What Xover order is better? caenot Multi-Way 30 23rd March 2006 05:53 AM
!st order series xover between 5"FR and woofer?? johnmark Full Range 1 2nd May 2005 12:40 AM
does lower order xover have any advantages? andy2 Multi-Way 3 20th November 2004 03:57 PM
Page generated in 0.08855 seconds (75.38% PHP - 24.62% MySQL) with 10 queries
