Hi people,
I recently got hold of 2 10" woofers for free, and since I am in need of a new subwoofer I decided try some designs on them. Although a reflex system would go down to 50 hz, i wanted it to go lower. One solution would be to equalize the bottom end, but this would seriously affect the excursion of the drivers at loud playback levels. So I tried a bandpass enclosure. After adding some mass, the response went down to 30hz, just what i was looking for. However this came with another problem, at about 70 hz there is a peak response of about 4 db's, that would not be acceptable. The response WinISD predicts: So this got me thinking: What if you equalize the higher freq. of the design? So i added an EQ to the design and this is according to WinISD the result. Response: Group delay: ![]() Excursion @ 48 Watts: ![]() Impedance: ![]() specs: Drivers = 2x Philips AD10100/W8 Rear chamber = 60L Front chamber = 31.5L Tuning = 52Hz Now the numbers look good to me, but will such a design actually work? |
#2 |
Sorry, forgot some specs:
Added mass = 25 Driver configuration = Push pull (to cancel out odd harmonics) |
| Weird BIB Idea | BHD | Full Range | 25 | 5th April 2007 02:56 PM |
| Weird idea: measuring inductance with a gyrator? | DaBit | Power Supplies | 3 | 25th January 2006 06:52 AM |
| an idea - but will it work ? | FBLEAGH | Multi-Way | 4 | 14th August 2004 06:24 PM |
| Weird IDE network card idea | specialx | Everything Else | 0 | 10th October 2002 01:10 AM |
| the isobarik 6th order bandpass transmission line folded horn subwoofer idea | Yoda | Subwoofers | 3 | 24th October 2001 04:00 PM |
| Page generated in 0.07456 seconds (67.76% PHP - 32.24% MySQL) with 10 queries |
