Old 5th August 2004, 08:37 PM   #1
B.I.G is offline B.I.G  Romania
Question KEF B200-G horn loaded
I have this driver an i want to make a horn for it like this : http://homepages.paradise.net.nz/quadroph/digitor.htm
My question is should i expect such a huge SPL like David J McBean`s software says ?? i mean 118dB at 40HZ wtih just 70W (it reaches Xmax12mm ) of power is quite a bit for a 90DB speaker .
[Driver]
Brand=KEF b200G
Model=B200G
Manufacturer=KEF B200-g
ProvidedBy=luci
Comment=
DateAdded=20040730
DateModified=20040730
Qts=0.369
Znom=6
Fs=27
Pe=150
SPL=89.57
Re=4.7
Le=0
fLe=0
KLe=0
BL=6.82
Xmax=0.012
Cms=0.0014181
Qms=3.03
Qes=0.42
Rms=1.37183
Mms=0.0245
Sd=0.02453
Vas=0.121
Dia=0
Vd=0.000294
no=0.005515
Dd=0.1767
EBP=64.29
numVC=1
Hc=0
Hg=0
SPLmax=108.33
SPLmaxLF=89.94
USPL=91.88
alfaVC=0
Rt=0
Ct=0
gamma=278.36064
Rme=9.89626
Mpow=3.14583
Mcost=0
Gloss=0.028396
c=343.68
roo=1.20095
Thick=0
Depth=0
MagDepth=0
Magnet=0
Basket=0
Outer=0
Vcd=0
DVol=0
B.I.G
Old 6th August 2004, 12:42 PM   #2
so no one knows ??
i doubt that ....
B.I.G
Old 6th August 2004, 01:05 PM   #3
Banned
The model is stated in eighth space- corner loaded, that is- and as such the anticipated output is quite likely. It would drop precipitiously otherwise but yes, high output with low power is what horns are all about. Here is a link to a measured SPL chart for my Tuba 18, an 18" cubed box loaded with an eight:
http://hometown.aol.com/billfitzmaur...mtbrand=AOL_US
www.billfitzmaurice.com
Front loaded and back loaded horn DrWoofer.com Subwoofers 0 3rd August 2007 06:55 PM
B200, corner loaded bass reflex? jdybnis Full Range 10 18th March 2006 12:08 AM
KEF B200-G horn loaded B.I.G Multi-Way 1 5th August 2004 10:08 PM
Visaton B200 bookshelf horn hm Multi-Way 0 4th May 2004 09:20 AM
Need help with horn-loaded sub slicemaster101 Multi-Way 26 17th September 2002 01:09 PM
Page generated in 0.09306 seconds (72.84% PHP - 27.16% MySQL) with 11 queries
