Old 5th August 2004, 12:46 AM   #1
zuki is offline zuki  United States
Default what can make a passive cross over not work ? (explained)
i took the botton out of the definitive speaker
it has the crossover mounted to the back side.
i removed the woofers
2 different kinds that were installed in the cabinet and test them with a aa battery test i made
they work.
(now)
when i hook the speaker up to an amp
only the tweeters play.
not the woofers
so i tried testing different spots on the circuit (around choke coil)and still no sound.
the board looks okay.
except maybe the hot glue around copper winded choke is sort of loose, but nothing wrong visually with board.
it has some resistors on the board a yellow looking capcitor and the choke, and useual cross over stuff.
what can i check to sleuth the problem
thank you.
Old 5th August 2004, 01:26 AM   #2
also , can the ceramic like impedance resistor go bad ?
this cross over has 2 of them
when i jumper the wires with a battery
1 works
1 makes no sound
Old 5th August 2004, 02:18 AM   #3
1 works
1 makes no sound
Ceramic like impedance resistor?
You mean something that looks like this thing?
I would think you would test that with a simple meter. Just use the "ohms" scale.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 5th August 2004, 03:04 AM   #4
i was asking if one could go bad
Old 5th August 2004, 03:33 AM   #5
Josephjcole's Avatar
yes
Old 5th August 2004, 07:24 AM   #6
Vivek is offline Vivek  India
Can you find ouf if it is a first, second or third order crossover?
Thank God for DIY audio.
Old 5th August 2004, 12:28 PM   #7
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
First check if the woofer is OK by connecting it directly to the amp (by-passing the crossover). Should give you sound up to it's roll off frequency. If they play then it's in your crossover.
Old 5th August 2004, 07:34 PM   #8
Zuki:
Why guess if one can go bad or not? Just test the thing. If you don't have a meter then remove the resistor from the board and hook it up in series with any speaker. If the speaker plays, then your resistor is ok.
-Anonymous
Old 5th August 2004, 09:36 PM   #9
here is what i found so far
the choke although it appears to be soldered to board is not passing current
so i took a solder iron and heated the solder and the end of the choke moved a little
now after the solder cooled, i retested and it now makes sound through all the speakers
and now i have to put all the speakers back in to test if it works
my next question which would really help is.
since the speakers in both are all mixmatched
how can i determine which model is the original woofer that came in the speaker some have shields on them and some say vifa
but the part numbers don't all match
some even have inverted foam surround
i could order new replacement speakers as soon as i could confirm what goes in there from factory
i don't want to pay 87.00 or what ever each from the factory if i don't have to.
thank you
Old 6th August 2004, 03:47 AM   #10
zuki
Perhaps you didn't read my reply from your other post
re: speakers in a BP 30 , anyway as I stated I purchased a
definative 6.5 drivers at Parts Express buy out special. It
was sheilded but was in fact DEFINATIVE ,through my searches
I've only found one dealer that comes close "SEAS " and at
madisound they have them on special and after looking at
the definative web sight i know there not the vifa's . Almost
all of their smaller drivers in those bipolor speakers have INVERTED SURROUNDS. Go to WWW.madisound .com and
click on "sale" scroll down to woofers and you'll at least get a
good look at them , there are many 6.5 from SEAS that are not
sheiled
It,s people like you,that make people like me, hang out with people like that!
Hi:) and a passive cross-over question BMWTurbo Car Audio 7 26th November 2011 01:00 PM
Make an iPod work on Clarion c-bus MrRadi8 Car Audio 3 14th August 2007 10:06 PM
Can't make this address work..... Original Burnedfingers Tubes / Valves 4 7th July 2006 11:51 AM
cant make it work: mauro penasa rev 1 zafira1981 Chip Amps 14 24th December 2005 03:33 AM
Will this work- aperiodic port + passive radiator DeonC Multi-Way 6 5th August 2005 08:52 AM
Page generated in 0.12812 seconds (80.83% PHP - 19.17% MySQL) with 10 queries
