Old 4th August 2004, 02:57 PM   #1
biso is offline biso  United Kingdom
Default piezo tweeter connection
HI,
I am thick of putting about six piezo tweeter each 85x85x70 mm in one box without any other speaker inside it. can any draw me a diagram how best to connect them or any advice on connecting more then one piezo tweeter of any kind/type?
thanks
Old 4th August 2004, 03:03 PM   #2
Hybrid fourdoor's Avatar
I believe parrallel is best, because they have a super high impedence so it doesn't hurt your amplifier like normal drivers.
Some heldful reference from CTS...good read about Piezo's
I enjoy my organic shapes.....
Old 4th August 2004, 03:07 PM   #3
Depending on the amp's max output voltage, a series-parallel connection might also be recommended.
One question: Are these the only drivers connected to this amp or will there be woofers or mids as well ?
Charles
Old 5th August 2004, 08:25 AM   #4
Default Piezo tweeter connection
Hi Charles,
the main purpose is to connection them to the same Amp through an activie Xover. but some time I will like to connection the set with ather mid or woofer cab on the same amp.
will it make any difference.
thanks
Old 5th August 2004, 09:00 AM   #5
ekaerin is offline ekaerin  Sweden
ekaerin's Avatar
Do not forget to put a series resistor on each piezo. Dunno exactly
what value but somewhere between 10-50 Ohm should be OK.
If you make a high pass with the piezos just connect a 4, 8 or 16 Ohm
resistor in parallel with your series R piezo setup. Then calculate the
high pass as usual for the parallel resistor (4, 8 or 16 Ohm).
Regards / Mattias
Old 5th August 2004, 09:52 AM   #6
Some amps will not like the "pure piezo" as a load. The remedy has already been mentioned by Matthias: Series resistors.
Charles
Piezo Tweeter for Dogs Gold_xyz Multi-Way 80 15th October 2011 10:59 PM
Piezo tweeter help ivorcally Multi-Way 9 22nd May 2009 01:47 PM
Piezo tweeter to my BIB? gychang Full Range 8 13th November 2006 04:28 PM
piezo tweeter resistor UNDERSTANDIN Multi-Way 4 23rd September 2005 07:37 AM
Page generated in 0.08666 seconds (70.73% PHP - 29.27% MySQL) with 10 queries
