Hello from Maine,
I built an 15" Altec 620 cabinet and want to make it into a mono 'full range' speaker, I have a few questions and would very much appreciate some help :) All the cabinet has in it right now is an Eminece woofer from 1980, here are the specs from Eminence tech support : Eminence 15" woofer "661056 67-8020" It was manufactured for the Wurlitzer Company in 1980. It has a stamped steel frame, 54 oz magnet, zurette dust cap, 2" voice coil and is 8 ohms. It was manufactured before there were T/S params. This spec is particularly unique because it uses a paper cone with a paper edge and a 4 layer coil (Very unusual combination). The wattage is 150Watts rms continuous. I have ordered a 4" midrange and a 3" tweeter (Fisher, they are en route) My questions are : 1. Where in the cabinet should I mount the mid+tweet? 2. Where can I buy an inexpensive 8 ohm amplifier that'll send 150 watt rms to the woofer, 50 watt rms to the mid and 50 watt rms to the tweet (can I build a cheap one?) 3. Where can I buy inexpensive crossovers for these 3 drivers? (can I build cheap ones?) 4. Approximately where should I crossover each driver ? 5. There are a few "pin holes" in the woofers paper surround, what can I use to repair these holes? Thank you in advance for your help, Craig p.s. wanna build an arcade machine? see my tut here : http://spystyle.arcadecontrols.com |
#2 |
Hello again, I e-mailed this thread to Robert A. Booty, here is his advice (posted FYI, maybe it'll help other N00Bs)
on 8/6/04 12:42 PM, Craig Conway wrote: > Could you please look at my dilemma here? > http://www.diyaudio.com/forums/showt...242#post451242 *************************** > 1. Where in the cabinet should I mount the mid+tweet? Hi Craig, The mid & tweeter should be mounted above the woofer in a vertical alignment. Since your image of your cabinet shows the woofer toward the top, I'd recommend turning it upside down so that the tweeter ends up around ear level height. ![]() Having the tweeter unequal distances from nearby diffraction edges (eg: speaker cabinet edges) is good. (Assymetry in general is good in audio.) You'll of course need to build internal enclosures for the mid and tweet to isolate them from the woofer's internal back wave, unless they are closed back frames. I'm not familiar with the "Fisher" cone units you mention. > 2. Where can I buy an inexpensive 8 ohm amplifier that'll send 150 watt rms to the woofer, 50 watt rms to the mid and 50 watt rms to the tweet (can I build a cheap one?) An amplifier is not what controls the proportion of power that goes to the drivers. That's the crossover's job and it depends on the crossover points and the frequency content of the program material you play (the type of music). Modern solid state amplifiers are fairly inexpensive these days. Mono amps are not very common, but you should be able to buy a 50 to 100 watt/channel stereo amlifier (or probably more commonly a complete receiver) at something like "Best Buy" stores for around $100. You might try cruising this site: http://www.jr.com/ You don't need to have a 150 watt/chan amplifier just because your woofer is supposed to be rated at "150 watts". Remember 150 watts is only 3dB louder than 75 watts. :-) I would expect that woofer to be fairly sensitive (probably 90+ dB/watt @ 1 meter ???). Around $300 is probably a fair price for a new 150w/chan home stereo power amplifier. My amplifier page http://home.new.rr.com/trumpetb/audio/schem010.html could provide some ideas to build a 150 w/ch amp, but not necessarily any cheaper than you might buy a complete unit. Familiarity with schematics, sizing and purchasing the components, some basic shop skills and soldering skills are prerequisites for a project like that. It's a lot of work. The payback is not much cost saving, but the self satisfaction and learning new tricks that come with it. > 3. Where can I buy inexpensive crossovers for these 3 drivers? (can I build cheap ones?) Thses are good sources for components (coils, capacitors, resistors) or complete crossovers... http://www.madisound.com/ http://www.mcmelectronics.com/ http://www.partsexpress.com/ You can build crossovers, but some research and study is probably involved to take off from my crossover pages, eg: http://home.new.rr.com/trumpetb/audio/xoversch.html A book like David Weems: "Designing, Building, & Testing Your Own Speaker System" is a great resource to learn nearly all these things you should know for success in audio speaker projects like this. Check out http://www.amazon.com/exec/obidos/tg...112782-2499060 ?v=glance or maybe Google for weems speaker book > 4. Approximately where should I crossover each driver ? If the page http://home.new.rr.com/trumpetb/audio/crpts.html doesn't make any sense, then I'd just suggest that a 15 in. three way system like you're proposing probably would use cross points of 500 to 800 Hz for woof to mid, and 3000 to 5000 Hz for mid to tweet. "Second order" or 12dB/octave slope is good. You'd normally connect the mid with reverse polarity to compensate for the phase reversal of this circuit. 500 Hz is good for the woofer but your mid would need to have a resonance of 250 Hz or less, and I suspect that a 4 inch mid would be higher than that. (The cross should be at least an octave above the mid resonance.) > 5. There are a few "pin holes" in the woofers paper surround, what can I use to repair these holes? Hmmm, you might try diluting some "Elmer's" glue (with water) and brushing it around the areas of the "pin holes". Practice on some paper scrap pieces first. Good luck, Craig. Bob -- Robert A. Booty Oshkosh, Wisconsin, USA Oshkosh Brass Quintet - http://home.new.rr.com/trumpetb/ Locomotive Animation - http://home.new.rr.com/trumpetb/loco/ Wt. & Bal. Calculator - http://home.new.rr.com/trumpetb/alph/ Home Audio Projects - http://home.new.rr.com/trumpetb/audio/ Franklin Elementary - http://my.athenet.net/~franklin/ Damon's Kitty Buds - http://webpages.charter.net/shirleygr/damon/ Horse Pal fly trap - http://www.bitingflies.com/ |
| Altec 811B horns and Altec 414z 12" Speakers | xecluded | Swap Meet | 0 | 21st September 2008 05:21 AM |
| Altec Lansing 617-8A; 12" Duplex; Ceiling Loudspeaker | hoakd | Multi-Way | 5 | 14th July 2008 04:11 PM |
| t-amp and 5.1 (n00b) | metfoo | Class D | 5 | 21st August 2006 11:30 PM |
| Yet another n00b | matjolic | Introductions | 2 | 27th March 2006 02:11 PM |
| Altec loudspeaker : Newbie needs advice please :) | SpyStyle | Multi-Way | 9 | 11th February 2004 01:35 AM |
| Page generated in 0.06970 seconds (73.90% PHP - 26.10% MySQL) with 10 queries |
