Old 3rd August 2004, 07:39 AM   #1
runer is offline runer  Norway
Default THOR with curved side walls?
I'm going to build a D'Appolito THOR loudspeaker, but if possible I would like to build it with curved sidewalls instead of the original box design. I'm pretty skilled at woodworking, so the construction is not a problem, but I don't have enough knowledge to say how this will affect the sound.
If I design the cabinet so that I basically keep the internal volumes of the original design, will I be OK? As the cabinet narrows towards the back, I plan to make it deeper to keep the same volume, and same tapering of the transmission line.
The internal reflections will of course be different with curved sidewalls, but will this really make a difference?
Opinions anyone?
Rune.
Old 3rd August 2004, 01:30 PM   #2
Banned
As long as the cross section, taper and so forth remain the same it's fine. The internal reflections are not really a consideration, as the stuffing suppresses them anyway irregardless of the line shape. That's one advantage to a TLine, in that the stuffing renders the presence of parallel walls moot. It's a very different story in a horn, where stuffing can't be used and flat/parallel walls are quite detrimental to midrange response.
Curved Small Thor Build Renron Multi-Way 102 20th January 2008 01:03 AM
My sand filled curved side walls project in progress! sqlkev Multi-Way 17 11th August 2006 05:27 AM
Pvc pipes for curved walls polkymon Multi-Way 13 26th October 2005 01:23 PM
making curved walls thin paulspencer Subwoofers 2 10th December 2004 06:59 AM
Curved side 2.5 way - one down, two to go dhenryp Multi-Way 4 8th March 2004 09:18 PM
Page generated in 0.07925 seconds (71.68% PHP - 28.32% MySQL) with 10 queries
