Old 2nd August 2004, 08:01 PM   #1
validator's Avatar
Question BSC with open baffle array
this might be a stupid question but:
I want to build a kind of open baffle line with 8x 4inch widerange driver surrounding a horn tweeter. The baffle is about 6inch wide and 40inch long. Do I need to implement a baffle step correction?
Thanks in advance
Thorsten
Old 2nd August 2004, 09:58 PM   #2
Timn8ter's Avatar
I don't think so, but you may want to consider a wider baffle unless you're running a mid-bass array along with it. Your frequency roll off with a 6" wide baffle is going to be very high.
Old 3rd August 2004, 01:20 AM   #3
5th element's Avatar
Hmm reading this got me calculating. My OB's are 30cm wide and when measured fall off at about 500hz, but theory says this should occur at about 1000hz? Im confused unless my mathmatics is somewhat flawed this early in the morning.
Anyone care to explain please.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 3rd August 2004, 01:35 AM   #4
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
I don't know the calculations but the graph I use show even lower for a 30cm baffle http://www.angelfire.com/electronic/...oncept-1b.html
5th Element,
You are probably only considering the width, not the height plus the free ride of the floor.
Everyone has a photographic memory. It's just that most are out of film.
Old 3rd August 2004, 08:23 AM   #5
Rudolf is online now Rudolf  Germany
Rudolf's Avatar
Default BSC with open baffle array
Thorsten,
with the "8" radiation pattern of a dipole there is no baffle step - by definition and by function. Did you try http://www.tolvan.com/edge/
to simulate the frequency response and edge diffraction of your OB?
The baffle you are suggesting should support f3~300 Hz, but those 8 drivers might move f3 down a bit.
Rudolf
www.dipolplus.de
Old 3rd August 2004, 08:38 PM   #6
Hmm my baffles are 30cm wide and the front of the panel is about a meter tall. The rear of the panel is 30cm tall. The panel sits atop a boxed woofer.
Old 3rd August 2004, 09:10 PM   #7
Timn8ter's Avatar
This topic was about beat to death in another thread. Chances are there is more going on than one equation is going to account for. Your measurements tell the real tale.
Open baffle Line array carpenter Full Range 81 21st July 2010 10:50 PM
Open Baffle Line Array 24kilo Multi-Way 11 24th September 2005 04:10 AM
line array open baffle spkerguy Multi-Way 5 6th January 2004 08:42 AM
Open baffle line array ryoshu Multi-Way 15 15th January 2003 11:10 AM
Page generated in 0.09243 seconds (75.78% PHP - 24.22% MySQL) with 10 queries
