Parameters:
Qes = 0,364 Qms = 3,03 Qts = 0,325 Pe = 120W dia = 12" SPL = 90dB Re = 6,7 ohms Z = 8 ohms Mms = 38,4 g Hcoil = 17mm Hgap = 7mm Fs = 27Hz Bl = 13,5 Tm Sd = 0,0531 m^2 Vas = 260 l Xlim = +/-13mm I have access to this pretty cheap speakers, and want to make subwoofer which goes really deep. I want response from 20 to not higher than 60 Hz. What box would you recommend ? Will I get less distortion if I put the drivers in push-pull configuration ? Thanks ! |
#2 |
If you want smooth response, 30 Hz is about as low as these will go. And that will be in a big, big box-about 7 or 8 cu ft.
"A friend will help you move. A really good friend will help you move a body." -Anonymous |
#3 |
Banned
The best you can hope for here is an F3 at 35Hz from a 4.5 cu ft VB tuned at 33 Hz. Almost any driver that you want to run strong to 20 Hz will have to start off with an Fs lower than that.
The exception is a horn-loaded cabinet, which this driver could take down to 20 Hz no problem. Got room for a 14 foot horn? |
#4 |
Do you have two?
Take a look at this coffee table horn (click 'plans' they are free) http://www.decware.com/newsite/mainmenu.htm Groovy? Craig |
| Recommend a woofer for Fostex FE103E | tpsorin | Multi-Way | 7 | 9th August 2009 05:05 PM |
| SUB woofer enclosure size | sumovanner | Subwoofers | 3 | 4th December 2008 04:32 PM |
| Please recommend a 15" woofer for a dipole | navin | Multi-Way | 91 | 4th July 2007 05:20 AM |
| Please recommend a woofer. | 1Time | Multi-Way | 17 | 5th February 2003 05:39 AM |
| Page generated in 3.64612 seconds (2.15% PHP - 97.85% MySQL) with 11 queries |
