Old 2nd August 2004, 02:28 AM   #1
Default The ultimate midrange driver?
Community Professional M4 compression driver.
Has anyone tried one of these for home use?
Where can I get them and which horn would you use?
4 inch throat, 114 dB SPL 1W/1M -
Cheers
RB
RB
Old 2nd August 2004, 02:35 AM   #2
Anything under 115 db is wasting your time
Old 2nd August 2004, 04:10 AM   #3
Default M4 specs
Here are the specs. A monster of a driver. I must have them, my pleads have been answered!
I think I will drive it with a 1W Class A amplifier!
RB
Old 2nd August 2004, 02:25 PM   #4
Swedish Chef's Avatar
I like the carrying handle!
"Knowing what to do but not why is no use in a changing world" - The Art of Sound Reproduction
Old 2nd August 2004, 02:46 PM   #5
One thing is very peculiar: They couple the convex side of the diaphragm to the horn throat.
The throat is usually coupled to the other side of the diaphragm for good reasons !
Charles
Old 2nd August 2004, 02:47 PM   #6
GM is offline GM  United States
GM's Avatar
Hmm, for HIFI use, a ~1.8kHz XO point is not where I want to put one regardless of all the consumer/DIY designs that put one in our most acute hearing BW.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 2nd August 2004, 07:48 PM   #7
ScottG is offline ScottG  United States
not quite as much low-end bandwidth but better distortion for a given freq.
http://www.bmspro.com/products/4591.html
perspective is everything
Old 2nd August 2004, 11:02 PM   #8
I dunno, from glancing at the specs, no comparison I think. The M4 goes down an extra octave and the distortion figures are extremely low. They are given for 10% output and 100%. If I am reading this correctly this means at 20W and 200W program power, not 1W/1M as the BMS product. I draw from this that we got 114dB at 1W, therefore 131 dB at 1M for 20W with less than 1.5% second harmonic (at 1KHz!) and, well MUCH less third harmonic distortion, which would be the evil one here. It looks like less than 2% 3rd harm. distortion at 200W= 137 dB SPL! ..and it goes down to 300 Hz
I gather you would probably need a minimum of 8 high regular pro low midrange direct radiators to come even close to this performance in SPL and their combined distortion figure could not come even close.
******* awesome specs, but the thing could sound like a trashcan. Correct me please if I am wrong.
RB
Old 2nd August 2004, 11:03 PM   #9
I gather you would probably need a minimum of 8 high regular pro low midrange direct radiators to come even close to this performance in SPL and there combined distortion figure could not come even close.
The BMS driver has a MUCH smoother response.
Old 2nd August 2004, 11:23 PM   #10
Big Gun,
Are you speaking from experience, or are you looking at the charts?
I am having a hard time with these little smoothed charts, I need to get better glasses...
Don't get me wrong though, the BMS stuff looks as if it is VERY affordable!
RB
Ultimate real fullrange driver hugobors Full Range 163 19th September 2008 04:25 PM
L-pad attenuator for midrange driver 6 1/4 inch driver rhythmdiy Multi-Way 0 4th November 2007 03:32 PM
Frogs: The ultimate midrange? Cal Weldon Multi-Way 69 4th May 2006 12:50 PM
Ultimate Subwoofer Driver cemmany Subwoofers 128 5th April 2006 07:42 PM
Page generated in 0.12199 seconds (82.87% PHP - 17.13% MySQL) with 11 queries
