for the next project, .. I want to use my pair of OEM (aura) linaeum dipoles tweeters. Thinking of a small / medium sized bookshelf that can be used in the bedroom or on a shelf.
hence, .. 1. small size implies probably a ported design to get a decent amount of bass (though i haven't shut myself out to sealed boxes yet, for this design). doesn't need to go real low, as a sub will be available if needed, ..just enough to make them listenable without a sub. 2. at the back of my head, i was thinking mini transmission line (a la PMC bookshlef) .. but have no idea where to start on that one, .. or how it sounds 2. preferably front ported,.. as it may be mounted against the wall 3. the dipole tweeter will obviously be top mounted looking for woofer / midbass suggestions and also design suggestions. most of the designs on the web suggest the use of the tonegen woofer which i can't see available anywhere. in any case,.. there must be other suitable dirvers out there too. i was thinking of using speaker workshop to design this speaker (or maybe the easier to work with win-isd if speaker workshop continues to frustrate me questions: 1. compatable driver suggestions 2. does anyone have the T/S paramters / freq. curve for the dipole. the OEM linaeum monopole ispecs are are at http://www.aurasound.com/pdf/ntl25-354-4a.pdf but not the dipole. 3. budget, .. want to keep this fairly inexpensive (say, .. under $50 - $70 for two drivers and crossover components). BTW, .. i have a pair of boxes of size 0.9 cu. ft from a previous project (missing the front baffles). might these come in useful?
"Any fool can know. The point is to understand" - Albert Einstein |
#2 |
frugal-phile(tm)
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
I can recommend the Dynaudio 17w75EXT mid-woofer as a great mate for the Linnaeum tweeters--I built a two-way system in a truncated concrete tube that I've enjoyed very much for the last 11 years. The tweeter sits on top, of course, while the Dynaudio produces an amazing quantity and quality of bass from the tube underneath. This is probably a much larger (and heavier--100lbs each!) route than you would want to go with but perhaps the same drivers in/on a small, well-designed bass reflex box (made out of Corian, perhaps?) might also be a good choice. Sorry, but I no longer have the specs on the Linnaeums any more but I seem to remember smooth response up to 26khz...
The Dynaudios are frequently available on ebay and I think can also be obtained from European sources (search this site) if you are interested. Good luck with your project! Jeff in Hawaii
#4 |
I second the MCM 1855/1870 recommendation. It works well in a small BR box and blends well with a linaeum. I had some mini speakers with the 1870 and linaeum monopoles a few years ago.
Don't waste money on 'fancier' woofers. Those tweeters are pleasant and OK sounding, but don't warrant the hype they used to get. The little MCM woofers kick butt for the size, and respond well to tweaks like a phase plug, coating, etc. GB |
#5 | |
what do you cross over at (and what type of crossover ckt)? thanks hmm, .. dynaudio, .. will keep at the back of my mind, .. but this was supposed to be a budget project
#6 |
I think the crossover was a 1mH lowpass choke, and a 4.7uF highpass, with an L-pad on the linaeum. 5R/10R series/parallel, IIRC.
This had started out as a ratshack prox77 (?), and I just tossed the original woofer, which was unlistenable, and hotmelted in the 1870. Yeah, quick and dirty... The crossover was what was in there already, 'cept I put in a film cap, and added an L-pad with a couple extra series ohms to pull down the xover point a little. You might do better with a more carefully designed crossover, but that one worked good enough. GB |
#7 |
frugal-phile(tm)
When i used the 1855, i added a bit of cone treatment, which killed the bit of a breakup peak they had and was able to run them full range with the tweeter (not a linaem) rolled in 2nd order.
dave
#8 |
ALthough I don't have any graphs or anything, I think I remember the Lineums (at least the ones I have PN# 40-1389) were OK down to about 3Khz...but would probably need a 3rd or 4th order XO.
BTW, Dave that picture of you hanging upside down or something was the best one yet....artistic
I enjoy my organic shapes..... |
#9 | |
frugal-phile(tm)
Current one is making molecule models in Grade 12 chemistry (i was in Grade 11 -- 17 Years old i guess) dave
#10 | |
| Webhosting Wanted - UK based host preferred | Geek | The Lounge | 5 | 11th May 2008 12:01 AM |
| WANTED - 6080/6AS7 Based Amplifier | baileyler | Swap Meet | 1 | 26th March 2008 10:17 PM |
| wanted: aleph-p PCBs based on veteran's design | jarthel | Swap Meet | 0 | 10th July 2007 04:55 PM |
| Wanted: Dac pcb for tda1541a (non tube based) | ash_dac | Swap Meet | 6 | 7th January 2006 05:44 PM |
| Amp Suggestions Wanted! | Tall Shadow | Solid State | 20 | 9th December 2002 01:25 PM |
| Page generated in 0.12803 seconds (83.03% PHP - 16.97% MySQL) with 10 queries |
