Old 1st August 2004, 07:38 AM   #1
Hybrid fourdoor's Avatar
Question Another line array thread!
A question along the lines of the 0.69 wonder.....
Consider the following driver. What looks to be a laptop computer or something....
Although by themselves they probably don't put out much, how do you think 30 or so per side would do?
Their only rated at 0.4W each, but with 30 of them per side, they would hardly need any power for normal llistening (80-90dB). I don't even know what to call this style of driver...i tried searching small flat speaker, small thin speaker, but just got normal stuff (like "this speaker has small enclosure that is also thin", or NXT speakers). I didn't know if these are called specific types of drivers.
I can buy 60 or so of these for less than $15....do you think it would be interesting? I think a line of 1.5" holes on a baffle would work....possibly high pass all the bass (below 100Hz) out to keep the excursion low.
I enjoy my organic shapes.....
Old 1st August 2004, 12:40 PM   #2
SY's Avatar
What's the resonance frequency? That might choice you a bit as regards the LF crossover point.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 1st August 2004, 01:00 PM   #3
Send a message via AIM to bhg41088 Send a message via MSN to bhg41088 Send a message via Yahoo to bhg41088
Do you have a link to these? Also, on another point, i was playing with 2 8 ohm 2w 2" speakers yesterday, highpassed at 120hz, and they were taking all of 30-40rms and stayed fine. Those will handle alot more than .4w with a higher crossover, just like the Tangband w3-871 will take 100 watts when HP 2nd order at 400hz.
Old 1st August 2004, 01:22 PM   #4
Banned
Using a large quantity of these will give power handling and semsitivity but it won't change the F3. I'd be sure to obtain the relevent specs and do a WinISD sim to be sure that they'll reach your intended F3.
Old 1st August 2004, 02:31 PM   #5
Swedish Chef's Avatar
Hmm, these "equipment speakers" usually have a diaphragm of stainless steel to make them more weather resistant. Not that a metal diaphragm has to be all bad (after all, titanium/beryllium/aluminium compression drivers can sound wonderful), but stainless steel... well I sort of have my doubts... Also fq response might be anything but flat.
But it sure would be interesting to see have 30 or more of these would perform in a LA! Keep us informed!
/Magnus
"Knowing what to do but not why is no use in a changing world" - The Art of Sound Reproduction
Old 2nd August 2004, 01:31 AM   #6
I think the chances of finding any graphs on these are gonna be next to impossible. But like I said $12 for 60 ain't a real bad investment even if there crap
Perhaps some Piezo's crossed over at 2KHz would take away any harshness these would probably have.
Old 2nd August 2004, 12:52 PM   #7
onis_uk is offline onis_uk  United Kingdom
they are called Super-Thin Mylar Speakers i believe
Another Line Array Speaker Thread dhenryp Multi-Way 35 3rd December 2005 05:59 PM
Line array tweeter line - On left or right? dhenryp Multi-Way 4 9th March 2005 11:35 PM
yet ANOTHER PE 269-570 line array thread MEXXX Multi-Way 17 7th October 2004 06:26 AM
how to combine Line array and transmission line together Jared Multi-Way 5 19th April 2004 10:32 PM
Page generated in 0.10391 seconds (77.58% PHP - 22.42% MySQL) with 10 queries
