Old 31st July 2004, 07:48 PM   #1
Default If a baffle is 2 meters wide, what is the frequency where the sound
fires completely into 2pi space?
Old 31st July 2004, 10:16 PM   #2
Equilibrium's Avatar
divide the speed of sound by 2 meters
340/2=170
170Hz
give or take
depending on air pressure and temperature
more or less
Old 1st August 2004, 12:43 AM   #3
GM is offline GM  United States
GM's Avatar
Hmm, 'sound is round', so assuming a round baffle to keep it simple and SoS = 344.424m/sec, then as a rough approximation: 344.424/pi/2 = ~54.82Hz/F3, but there's a terminus end correction of radius*0.613 that needs to be accounted for: 344.424/pi/(2+(2/2*0.613) = ~41.96Hz.
If F6 is what you're looking for, then it is 1/2 octave away, or 41.96*0.707 = ~29.66Hz. Or just use Linkwitz's formula for F6: (0.17*344.424)/2 = ~29.28Hz. I assume the inaudible discrepency is due to him rounding the numbers off a bit in his lumped sum value.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 1st August 2004, 02:41 AM   #4
Hybrid fourdoor's Avatar
So...so far we got 144Mhz, 170Hz, and 42Hz. Anyone else????
You know how this scientific stuff is
"Industry, science, and technology! Big men putting screwdrivers into things! Turning them! And adjusting them!"
I enjoy my organic shapes.....
Old 1st August 2004, 03:21 AM   #5
Hans L is offline Hans L  Netherlands
Hans L's Avatar
F3 of 42Hz and fully into 2pi at 170Hz is pretty close. However, this is all theory. With these kinds of frequencies in a room, you will probably get completely different results due to roomgain and standing waves.
In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move. --- Douglas Adams
Old 1st August 2004, 03:21 PM   #6
Svante is offline Svante  Sweden
Svante's Avatar
Depending on how you define "fully" all answers are correct. Unless you really mean fully (ie nothing gets around to the back side), then the answer is "infinite".
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 1st August 2004, 03:34 PM   #7
pinkmouse's Avatar
rcavictim
Your comments are inappropriate for this forum, and not required here, so I have removed them to Texas. Please behave from now on or further action will be taken.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 1st August 2004, 04:11 PM   #8
rcavictim's Avatar
Originally posted by pinkmouse
rcavictim
Well 'ya see officer......here I was in the proper lane doing the speed limit when someone says "2 meters". Just so happens that triggers a nerve because I do care and am most concerned with the direction where amateur radio is going. I apologize for posting clearly off topic.
I.Q.Test. Have you ever purchased a recreational snowmobile?
Old 1st August 2004, 04:21 PM   #9
What does a distance of 2 meters have to do with amateur radio?
Old 1st August 2004, 04:24 PM   #10
GM's Avatar
Hmm, obviously I was not thinking in terms of F0 WRT 2pi space radiation, but it would be 1/2 octave above F3, or 1.414*~41.96 = ~59.33Hz, so I don't see how ~170Hz or any other frequency 'up' to 'infinite' can be correct, especially since 'infinite' as I understand the term = DC.
GM
B20's, sealed, wide vs narrow baffle? 2litre Full Range 15 21st March 2010 08:30 PM
Fr125S: wide or narrow baffle bro Full Range 28 1st November 2006 09:15 PM
Possible wide baffle project Scottmoose Full Range 6 25th September 2005 01:16 PM
narrow vs wide baffle and port location....? AudioGeek Multi-Way 3 9th May 2004 09:19 PM
Page generated in 0.11896 seconds (82.71% PHP - 17.29% MySQL) with 10 queries
