Does anyone know what the sensitivity of Fostex 206E horns in the 208EZ enclosure would be? The drivers themselves are 96dB and I know that the overall sensitivity of the speaker increases when mounted in a horn enclosure, but I don't know how much.
I've heard that the sensitivity can go up to 100dB in this enclosure, but I've also heard that it may only go up a few dB (say, to 98dB), so I'm confused. I'd really like to know since I have some tube gear on the way, so if anyone can help I'd really appreciate it. Also, if anyone can help me with a new UN resolution on Iran, I'd appreciate some help there too. I'm stumped. Thanks! Kofi |
#2 |
Don't know, but from just looking at measured specs I can speculate that the FE206E is only ~94.4dB eff. Vs the FE208ES's ~95.5dB in the horn related BW, and that the filter chamber/throat is too large for the FE206E, so you may need more series resistance than your system has and you may also need to experiment with reducing the filter chamber's Vb for best in-room response once you find the optimum amount of added series R. This means that the final system efficiency will be <the driver's base efficiency and some digital EQ shaping may be required for best in-room performance.
WRT horn gain, it is dependent on a number of variables, and for a properly done BLH it is designed to be anywhere from 2-6dB higher than the driver's base efficiency, IOW just enough to make it ~flat in room ~an octave above the design Fc, so while they are technically horns due to having a LP filter/positive expansion, their gain is more like that of an unstuffed TL. Few achieve this though without significant EQ shaping unless designed for the specific app. WRT the Middle East in general and radical Muslims in particular, I'm rapidly swinging to 180deg of politically correct, so can't offer you any peaceful suggestions. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#3 |
Banned
The overall sensitivity doesn't change in a rear loaded horn. Model the driver in a vented box in WinISD and you'll see that it has practically no bass response; this is due to the very low Qts, the price you pay for high sensitivity. What the rear loaded horn does is to tap the rear wave of the driver and use horn loading to add gain that will raise the bass response hopefully to the same level as that of the front wave.
www.billfitzmaurice.com |
#4 | |
Thanks for the information! My next question (since there's always a next question) is will I get a reasonable response with a 3.5W SET tube amp? I'm not looking for arena rock sound level, mind you, but I would like to engage in moderately loud listening levels when say, Jacques Chirac and Gerhard Schroder drop by.
Thanks, Kofi |
#5 | |
You're welcome! Beats me, I mean one man's moderately loud is another's TV viewing level. Figure in-room system efficiency is 93dB/m, then adding 10*log(3.5) = ~98.44dB/m. Factor in room dependent loss over distance and there's a good chance you'll be clipping the amp if other than chamber music is played. I don't care for it, but many folks find the clipping of tubes euphonic, so maybe this will be adequate.
Back when I was semi-serious about this stuff, I used to regularly clip a Mac2300 driving ~107dB/m eff. 70-500Hz midbass horns on selected organ an symphony vinyl/tape/CDs, though the average SPL was around 96dB/m, or ~'live', but heavily compressed/limited R&R, etc. should play plenty loud unless the room is large/open and you sit far away, so as always YMMV. Quote:
GM
#6 | |
Thanks for the information. I do listen enjoy the rock and roll, jazz and soul music, so hopefully these will perform OK. I sit (or lay down, or weave drunkenly back and forth) about 8' - 10' from the horns, so I'm thinking the volume output will be adequate. Looks like you live near me (I'm in the Atlanta UN building) so if you hear an overall loudness in your general vicinity followed by a legal announcement in the AJC that Mrs. Annan is filling for divorce, that's me. Thanks again. Kofi |
#7 | |
You're welcome!
Whatever happened to the game of Warlords, chess? Seems to me this would be the obvious choice. Anyway, Some Jazz/Soul will clip the amp, so I guess it will be a matter of whether or not it's objectionable to you. Quote:
GM
#8 |
I've never been to the Atlanta DIY, but I'd like to attend. I'd be glad to bring the horns, only I made them out of 3/4" MDF (and they're not exactly works of art) and I would say that, without exagerration, they weigh approximately 75,000 lbs each.
I would, however, be glad to view others' stuff and make uninformed, completely ignorant comments: "What's that round thingee on top there?..." I just started with this DIY Audio stuff only recently and while I have already built a fair amount of gizmos, I'm still learning and a bit intimidated by those in the know. Let me know if and when you have a meeting and maybe that will give me the guts to finish my cabinets and properly damp(en?) them. Also, I will need to enlist the help of several pirates and / or professional wrestlers to move the damn things. Kofi |
#9 |
They can't be as heavy as some of the systems folks bring. My estimated 350 pounders ARE a bit much to haul around though, even with their casters/handles.
Many (most?) of the folks who show up are like you, IOW have only built either kits or copied on-line designs. Heck, every year I've been one of us 'experts' has had to tell someone to swap their tweeter polarity, fix a connection, or similar newbie mistake, so I wouldn't be too concerned about whatever level of 'expertise' you're at. WRT level of finish, some bring unfinished or basic flat black primered, so even if you didn't finish them it's no big deal. I know how you feel though. The first year I went, all I had was some unfinished RS 40-1354 'fullrange' towers (ML-TL) I was building for a friend, and almost took them back home when I saw the professional fit/finish level of some. Anyway, historically it's been up the street from me in Doraville the 3rd Saturday in October, but we vote on the date every year and there's been some talk of moving to a different location and possibly making it a two day event. There's a website set up, so sign up and get updated: http://groups.yahoo.com/group/DIY2004-Atlanta/ So what's the 'Atlanta UN building' you speak of? Your home? GM
#10 | |||||
I'll sign up for updates for the meeting and I guess I'll see you there. Thanks for the encouragement. Kofi |
| horns | jzeleznik | Multi-Way | 2 | 5th March 2009 07:25 PM |
| DIY 3-way horns | heifisch | Multi-Way | 22 | 5th April 2008 05:21 PM |
| smith horns and using compression horns for a Karlson party speaker project | bikehorn | Multi-Way | 10 | 27th December 2005 09:10 AM |
| T-Horns | layertone | Full Range | 21 | 28th October 2005 08:17 PM |
| Horns: Vibrations and resonances in metal horns | Rocky | Multi-Way | 10 | 28th July 2004 01:38 AM |
| Page generated in 0.14987 seconds (85.71% PHP - 14.29% MySQL) with 10 queries |
