Old 29th July 2004, 12:58 AM   #1
wingman is offline wingman  Denmark
Question dipole with Vifa M21WP
Hi
Will this speaker be good for Dipole use ?
Vifa M21WP-00-16 data:
Vas: 56,76
Fs: 34,1
Qts: 0,43
Qes: 0,52
Bl: 11,69
Re: 11,04
Sd: 235
Mdd: 29,92
i´ll to build a dipole speaker like the ORiON or Arvo Part project
and only use one stereo amp (icepower 250Wx2)
thanks for you input
bass is also audio
Old 29th July 2004, 01:04 AM   #2
From what you've told us, there's nothing glaringly obvious about its drawbacks. However, do you know if it has a pole piece vent or some other method to relieve pressure changes between the diaphragm and the pole piece?
Old 29th July 2004, 01:10 AM   #3
sorry but i do not know that.
I was hopeing that sombody would know the speaker
bass is also audio
Old 29th July 2004, 11:13 PM   #4
will the t/s work for dipole mid range ?
Vas: 56,76
Fs: 34,1
Qts: 0,43
Qes: 0,52
Bl: 11,69
Re: 11,04
Sd: 235
Mdd: 29,92
bass is also audio
Dipole Ribbon tweeter isolation from dipole mid-woofer array Bent Planars & Exotics 5 21st May 2009 12:10 PM
Vifa P17SJ and Vifa D27TG Large Bookshelf MTM rwo Multi-Way 7 24th February 2008 04:47 PM
(WW) MMTMM dipole – 4 vs 3 way / dipole benefit frequencies? charliemouse Multi-Way 25 7th July 2007 11:19 PM
help to find t/s on vifa m21wp wingman Multi-Way 2 13th July 2004 11:16 AM
Page generated in 0.07800 seconds (68.71% PHP - 31.29% MySQL) with 10 queries
