Given the interesting thread on dipole bass recently, and relevant comments in the "Ultimate DIY speaker ideas", I thought I'd post some pictures for anyone who might be interested.
These are my "ultimate" speakers (well until the next ones anyway......) - within the bounds of my current budget, skills, room and spouse factors etc! They are my interpretation of a system using a directional mid/top together with dipole bass to get the best of out of my room/space available. My design criteria were: high efficiency, compact design, aesthetics that would suit an old house, can be played loud when required, easy to obtain non "high tech" materials. See what you think: I have a lot of tweaking and changes to make still. For now I'm using my 2A3 SET to drive the Oris/AER full-range, into a passive line filter, then into the bass amp (IcePower 500w modules), Lambda TD15S units for the bass. As you can see - minimal baffle area - compact and generate fewer resonances, but heavy weight!! So far with this set up they sound great, better than all-comers in my room (various electrostatics, conventional, high-efficiency and a number of other horn-loaded systems over the years). The lack of room excitation on the bass is just uncanny. They create a huge sound stage but without the room joining in! The position for the units I've adopted sound the best so far, the listening postion is towards the back of the room (3.6 x 5.6m). There are modes along the room which are apparent as you'd expect - in the middle especially. I've been trying to get more time to do further measurement and improvements, but for the last 2 weeks I can't stop listening to my music collection! D Anyway, enough of my ramblings for now, do let me know if you have any comments, observations or ideas on how to improve things. Regards to all, Jonathan PS. Thorsten, if you see this, then yes, this is what we were discussing (via email) over 18 months ago!!: |
#2 |
Jonathan,
is it a TacT there on the floor? In such case, how much does it "better" the dipole performance? /Peter |
#3 | |
There are not many speaker systems that I would want in my room but yours would certainly be a candidate. Are those Lambdas (very) expensive?
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#4 |
Well I have to admit to a somewhat overwhelming sense of jealousy...
I do have some questions though about your open baffle set up... Do you need to use a large amount of correction circutiry with a baffle that small? What kind of low end extension do you get with them? Any guesses on how much power they need, I know you have 500 watts, do you think you are using all 500, or are you just leaving yourself adequete headroom? just curious Joe |
#5 | |
Previously: Kuei Yang Wang
Konnichiwa,
Sayonara |
#6 | |||
Hi guys, many thanks for the kind words.
A couple of replies: Quote:
Dipole bass seems to be all about the amount of air you can move for the least cone excursion. The reproduction of kick, floor and snare drums have to be heard to be believed! Quote:
I will post some measurement plots later, but basically its amazingly flat in-room down to around 35hz. There is a small roll-off from 100hz down, but no-where near the predictions. I may add a monopole sub at some stage for 35hz and below. On amp power, I was leaving myself adequate headroom, but also based on the theoretical calculations on how much power I'd need to EQ them flat!! Regards, Jonathan |
#7 |
Great stuff Jonathan! Good to see you making the best possible use of my "old" AERs
Don't forget you have a package to pick up here .... Brian |
#8 | |
Konnichiwa,
The room where the two dual Kappa 18 Subs are implemented houses two harpsichords, a small pipe organ, an electronic organ and a Piano Grande, to give some idea of the size, with around 500 Watt per channel there is enough bass down to around 30Hz to seriously fill the room. I suspect even a pair of Eminence Delta 15 LF could prove sufficient if cost is an object. Sayonara |
#9 | |
Thanks for the reply Thorsten, I'm certainly very pleased with the results so far (and I know there's more to come).
I haven't done a lot on positioning yet, by turning the drive units face on. But have tried it with the drive units being swapped over. i.e. the null facing into the corner, vs facing into the back wall. The difference is quite marked between the two. Quote:
What was/is being used for the mid/high range in that set-up? Cheers, Jonathan |
#10 |
Very nice, I'd like to try something similar....
| Dipole Bass and Oris Horn | CLS | Multi-Way | 18 | 8th October 2010 02:07 AM |
| Front & rear end DUAL Back Loaded Horn + Bass Reflex Hybrid Enclosure | nickthevoice | Multi-Way | 13 | 19th May 2009 03:09 PM |
| What does an Oris horn do? | Rick J. B. | Full Range | 13 | 30th December 2006 01:35 PM |
| front loaded bass horn without rear compression chamber? | paulspencer | Subwoofers | 9 | 28th October 2005 04:53 PM |
| DIY Azura/Oris type horn | BTW | Full Range | 0 | 12th October 2005 12:24 PM |
| Page generated in 0.11992 seconds (87.26% PHP - 12.74% MySQL) with 10 queries |
