Ribbons and active XO - problems?
Old 26th July 2004, 08:58 AM   #1
AJ is offline AJ  United States
Default Ribbons and active XO - problems?
I've been thinking of buying a pair of Fountek JP2 ribbon tweeters and I read the following at a site that sells them:
Electronic crossovers show a dead short to the amp, you must use a passive component too!
I understand the need to be careful with ribbons, but I had never heard of problems with active XO's (I'll be using one). Can anyone explain the meaning of this warning? What kind of passive components are they referring to? Maybe a high-pass 'safety cap" or some such?
Thanks,
Allan
Old 26th July 2004, 01:00 PM   #2
paulb is offline paulb  Canada
The statement makes little sense: if it's a 'dead short' how could it produce any acoustic energy?
It must mean to put a cap in series. A good idea regardless.
Old 26th July 2004, 01:13 PM   #3
BobEllis is offline BobEllis  United States
BobEllis's Avatar
I think what they meant to say is if you use an active XO, the driver presents a very low impedance load at low frequencies. a large value high quality cap will block LF, take care of dc offset and turn on/off thumps. Try 20 -30 uf to start.
Old 26th July 2004, 04:21 PM   #4
Thanks guys. That's kind of what I thought they were getting at but the "dead short" thing was confusing.
Allan
Ribbons and active XO - problems?Hide this!Advertise here!
Active 3-ways with solen active loudspeaker module soundemon Multi-Way 14 19th March 2009 11:17 AM
Behringer DCX2496 I want to try active biamping using it as the active xover. georgehifi Digital Line Level 3 15th August 2006 07:46 AM
Ribbons and active XO redux AJ Multi-Way 13 27th July 2004 07:45 PM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
active speakers - problems? secateurs Multi-Way 0 21st June 2002 02:42 AM
