Horns: Vibrations and resonances in metal horns
Old 28th July 2004, 01:38 AM   #11
roddyama is offline roddyama  United States
diyAudio Moderator Emeritus
roddyama's Avatar
Hi Rocky,
I've used metal (cast Al) for quite some time. If you hold up the horn alone in the air by its flange and give it a thump, it will ring like a bell. You can hear this resonance very distinctly when you play music through them. You need to damp the resonance in metal horns.
I've always used heavy rubber or neoprene and glue and strap it to the outside of the horn. The tighter the straps, the better. You can see what I did with my current horns here. After this treatment, if you thump the horn as before, the ringing will have dissappeared as the ringing while playing music through them has.
If you're making your own horns, I would suggest, what ever metal you decide on, to very the thickness of the horn walls to lower the Q of the resonance.
Rodd Yamashita
Horns: Vibrations and resonances in metal hornsHide this!Advertise here!
metal cone resonances, what direction, how to suppress? capslock Multi-Way 36 5th September 2013 06:36 AM
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 14 30th January 2013 05:20 PM
horns jzeleznik Multi-Way 2 5th March 2009 07:25 PM
mid top horns adircf Full Range 0 27th January 2007 09:01 PM
TAD and horns, where to get horns? Daveis Multi-Way 15 13th September 2006 01:07 PM
