Hello,
which 7inch bass/mid-driver is the best for a 2-way-speaker? ETON? ACCUTON (THIEL)? SCAN SPEAK? EXCEL? Thanx |
#2 |
Scan Speak has great bass, but are beaten in the mids by the Seas Excel series.. Seas Excel have some nasty breakup modes in the upper mids/highs, so they need a complex filter to battle this. complex filters are very likely to degrade your sound. Eton is better in the bass than both Seas Excel and Accuton, probably on par with Scan Speak, but is beaten in the mids by both Accuton and Seas. Personally, My priority from a 7'' would be best possible mids so I would be likely to pick Seas Excel or Accuton.. Since I'm not too found of big passive filters, I'd go with Accuton if relying on passive filters, and use Seas Excel if I could use active filters (24dB/oct LR w. notch trap or somethin')
#3 |
You might also take a look at C-Quenze (if you can find it). Their 6.5" is usable up to 4Khz (even at 60 degrees of axis).
Is that all there is? |
#4 | |
There is a single large peak at 5kHz for the W18EX (7" driver), which is outside its passband, so it shouldn't be that difficult to overcome. If you cross over low enough, you can use the W22 without any dispersion problems (i.e. under 1.6kHz or so) - that's what Linkwitz does in his Orion. He uses a Seas Millenium tweeter crossed over using a 24dB/oct L-R filter to a W22 at 1.4kHz. Such a crossover frequency does limit the speaker volume because the tweeter distorts more easily at lower frequencies, but seeing as this is a two-way, high SPL targets shouldn't be your goal anyway. |
#5 |
@ all:
Thanx alot. I think I will use Accutone, due to its higher sensetivity ovr the Excel. Kal |
#6 |
THe W18 EX and W22 have about same sens. as the Accuton drivers.
/Peter |
#7 |
@ Pan: Thank you very much for the hint. Excels are really good speakers, but I made the experience that the lack some dynamics, at least in the designs I listened to. But it is always hard to compare different drivers when you listened to them in different speakers since then you hear the whole speaker and not only the driver, So I might be wrong by saying that I experienced some lack of dynamics with the Excels.
Kal |
#8 |
I have very limited experience with excel but I liked what I heard from a 5" MTM.
I´ve several systems with Accuton 7" ers, the best/among the best IMO. /Peter |
#9 |
My W15CY's dont lack dynamics to say the least.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#10 | |
| Thiel & Partner (Accuton) C11 Tweeter | Yunick | Swap Meet | 0 | 25th October 2006 06:58 PM |
| Suggestions on what to do with Thiel / Accuton C82 drivers | Mattias S | Multi-Way | 1 | 6th June 2006 04:40 AM |
| Accuton (Thiel) C13-6 or C24-6? | cyclo | Multi-Way | 2 | 13th December 2005 09:33 PM |
| Eton vs Scanspeak vs Thiel vs Dynaudio | Adrie | Multi-Way | 2 | 7th August 2004 04:57 PM |
| C²95 mid-bass from Thiel & Partner (Accuton) | Cloth Ears | Multi-Way | 19 | 8th July 2003 01:52 AM |
| Page generated in 0.11746 seconds (77.17% PHP - 22.83% MySQL) with 10 queries |
