ACCUTON (THIEL) or ETON - Page 2 - diyAudio
Old 26th July 2004, 08:12 PM   #11
Kal is offline Kal  Germany
@ Rocky:
Who is CM? I would really appreciate his advice on using Thiel/Accutone!!!
What do I have to take care of when building a cabinet /damping for Thiel/Accutone in particular?
Thanx a lot!!!
Old 26th July 2004, 08:18 PM   #12
Rocky is offline Rocky  Norway
Rocky's Avatar
Originally posted by Kal
@ Rocky:
Thanx a lot!!!
CM=CeramicMan
He is probably lurking right around the corner
Old 26th July 2004, 08:29 PM   #13
Rocky's Avatar
Kal
Read this:
http://www.diyaudio.com/forums/showt...102#post315102
Old 26th July 2004, 09:15 PM   #14
Seas Excel is a good driver, but not exceptional. The sound lacks microdynamics compared to ScanSpeak and Audiotechnology. Yes you get transient detail in your face, but compared to ScanSpeak or AT not enough to give the music the touch of reality (it's hard to describe). The efficiency is also terrible low Can be utilized in a moderate sized enclosure
Eton; go for the 7" HEX this is the only 7" eton you have to consider. It's ultra clean bass is the best in his class (yes IMHO better than SS or AT). The mids can be almost as good as the AT or SS, but you have to work on the cross-over to achieve that (my AT driver isn't fully broken in, so my AT may leap ahead in this department). Needs about 18-22l don't put it in a too big enclosure.
ScanSpeak; if you like the emotianal and intimate approach you need this driver. No other driver gives this much intimacy and "being there" feeling. You only have to consider the revelator, because that driver delivers afore mentioned qualities in spades. Efficiency is a bit better then Seas but still not very high, the dynamics don't suffer. Needs quite a large enclosure.
Audiotechnology; at this moment my choice the mids can't be compared with any other driver I have listened. Natural and airy presentation. Very 'fast' transients and as Duck said very good of-axis behaviour resulting in a very wide soundstage. This driver reaches also very low in a small enclosure (<40 Hz -3dB in 15-18l)
Unfortunate I have never listened to a Thiel&Partners ceramic driver. So I don't know. On specs and the published graphs I would choose this driver instead of the Seas Excel and expect the same behaviour, but better.
I just want to add that this is my opinion, each person listens differently and has other "boundary conditions". As always it is just a matter of taste. You can't go wrong with any of these drivers.
And a final remark, you need a good design, these drivers deserve it. If you can't design a speaker take a good design. Otherwise you will be disappointed, especially with the cones which show great cone-breakups. The AT and Scan are the most fool-proof in that respect.
Old 27th July 2004, 01:30 PM   #15
@ LaMa:
Thank you very much for your sound description. It is really hard to chose the right driver!!!
Old 27th July 2004, 02:14 PM   #16
I more or less quoted you there (without your permission )
Btw you have a lot of listening experience. Apart from Accuton and maybe Focal and PHL, it nearly covers the whole current top market
Did somebody mention Vifa?
Is that all there is?
Old 27th July 2004, 07:35 PM   #17
Default re eton 7"
I am currently building a small bokshelf monitor using the ETON 7 " Bass Mid.
I am also using the 19mm Eton tweeter.
I hope to use 1st or 2 nd order on tweeter and hopefuuly mechanical roll off on the bass mid.
The cabinets are about 25 % there so still knocking them up.
Hopefully they will be as successful as my last ETON project using 2 x 8" ported 5" mid sealed and tweeter. These are fabulous very fast dynamic and the bass is utterly incredible, who needs a sub ?
I was hoping to use the pioneer 4" full range at $0.69 from Parts express but the shipping is $120.00 so this may die a natural death. I was going to do a BOSE 901 overkill copy using 20 4" per cabinet plus a fill in tweeter.
I have not used Accuton as they are somewhat pricey and i previously used Focal for my projects. I am now using ETON as i ffel the BANG PER BUCK IS pretty good.
Very pleased with the results so far.
regards David
regards David
Thiel &amp; Partner (Accuton) C11 Tweeter Yunick Swap Meet 0 25th October 2006 06:58 PM
Suggestions on what to do with Thiel / Accuton C82 drivers Mattias S Multi-Way 1 6th June 2006 04:40 AM
Accuton (Thiel) C13-6 or C24-6? cyclo Multi-Way 2 13th December 2005 09:33 PM
Eton vs Scanspeak vs Thiel vs Dynaudio Adrie Multi-Way 2 7th August 2004 04:57 PM
C95 mid-bass from Thiel & Partner (Accuton) Cloth Ears Multi-Way 19 8th July 2003 01:52 AM
Copyright 1999-2017 diyAudio
