Ferrofluid and its Effect on Distortions?
Old 24th July 2004, 06:58 PM   #1
brummkreisel is offline brummkreisel  Europe
Default Ferrofluid and its Effect on Distortions?
Hi y'all,
I have a question about driver motors with FFL. Does FFL decrease the stray field by providing a closed magnetic loop? As a secondary effect, the field strength in the gap would increase (*), but more importantly, diminishing the stray field would decrease nonlinearities due to the stray field, e.g. eddies in the aluminum (aluminium) VC former, and possibly even affect BL linearities? Or wouldn't it? What do you think?
(Whether or not there is an overall gain in motor linearity (temperature-dependent viscosity of the FFL and nonlinear mechanical losses etc.), is another, yet also interesting question.)
Thanks & Cheers,
bk
(*) A search in the forum came up empty, although at one point someone quoted a third person stating that the field strenght increase would be marginally at best. One would have to discuss which field (B or H) does increase (if at all) and whether the respective field increase translates into higher efficiency.
What do you mean, "c'est du pipeau"?
Old 24th July 2004, 08:53 PM   #2
GM is offline GM  United States
GM's Avatar
This subject gets a bit complex since you make a blend for the app. Here's an overview: http://www.ferrotec.com/usa/ferroflu...y_overview.htm
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 24th July 2004, 09:17 PM   #3
454Casull is offline 454Casull  Canada
You'd have to take into account that ferrofluid is not completely ferromagnetic; ferrofluid (as indicated by the latter half of the name) requires a suspension to contain the ferrous particles.
Old 24th July 2004, 09:42 PM   #4
D'uh! Of course - the fluid will orient along the field lines rather than bend the field... thanks, Casull, my mistake, what was I thinking... I'm getting old, I guess...
GM, thanks for the interesting link!
Cheers from Montreal,
BK
Ferrofluid and its Effect on Distortions?Hide this!Advertise here!
About first cycle distortions and memory distortions gaetan8888 Solid State 3 11th November 2007 07:15 PM
ESL distortions ? JinMTVT Planars & Exotics 2 25th November 2006 12:09 PM
Where to buy ferrofluid ? thylantyr Multi-Way 9 10th May 2005 07:42 AM
Do not understand ferrofluid. tade Everything Else 10 5th May 2005 01:27 AM
Ferrofluid tweeter misshap! Tino Multi-Way 3 10th January 2004 06:27 PM
