Bipolar speaker configuration ...  need info! accoustical pros and cons ?
Old 29th July 2004, 04:53 AM   #31
JinMTVT is offline JinMTVT  Canada
Originally posted by planet10
Any sub is omni-polar anyway... having a pair of push-pish drivers has huge advantages with few disadvantages (except for having to buy 2 drivers instead of 1).
dave
ok sure thing DAVE!
but THEN LIST PLEASE!
hahaha
i need to understand at least a little
what is happening with bipolar?
and about softwares when desinging the box,
no one offers bipolar option, what should i take in consideration?
and also, if i put 4 drivers in the same box
2 pairs in bipolar kinda config .. wonder what it would do!
Old 29th July 2004, 05:11 AM   #32
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Well, i sort of implied you can't build a bipolar sub, because even a single woofer is omni-polar. The advantage of using a bipolar cinfiguration to build a push-push sub that gives you active force/vibration cancellation improving downward dynamic range, reduced transmitted vibration to the box, and no problems with seeing your sub dance.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 29th July 2004, 07:17 AM   #33
dave
well that's the kind of good information i'm looking for ..
so is it worth it to use bipolar config on sub?
what are the cons?
i am expecting largrer volume enclosure required ..but not 100% on that one..
Old 29th July 2004, 08:33 AM   #34
frugal-phile(tm)
planet10's Avatar
Originally posted by JinMTVT
what are the cons?
You have to buy 2 drivers...
dave
Old 29th July 2004, 06:21 PM   #35
GM is offline GM  United States
GM's Avatar
>please guys! back to the BIPOLAR subject!
Multi-channel playback is relevant to bi- and di-polar speaker designs.
>NEED MORE INFO ON BIPOLAR CONFIGURATION
the + and -
implications .. drivers requierement
is it good in use for sub?
Already answered.
>for mid?
frequency related problems?
No, though can work well if a more diffuse soundfield is desired.
>enclosure design considerations ( volume? )
For a given alignment, Vb doubles.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 30th July 2004, 05:47 AM   #36
is there any enclosure design software wich has an option for multiple drivers?
does it have bipolar config? or should i use anything with 2 drivers on the same enclosure will pretty much do the trick?
Old 30th July 2004, 05:21 PM   #37
GM's Avatar
>.......or should i use anything with 2 drivers on the same enclosure will pretty much do the trick?
Correct.
GM
Bipolar speaker configuration ...  need info! accoustical pros and cons ?Hide this!Advertise here!
pros/cons of a 845 VS 211 jarthel Tubes / Valves 2 18th June 2007 12:57 PM
Pros and cons of corner placement nunayafb Multi-Way 9 5th May 2006 09:08 AM
TL vs MLTL, pros and cons Tomac Multi-Way 5 29th December 2004 12:55 PM
Filterless DAC - pros and cons? mr_push_pull Digital Source 1 11th August 2004 02:56 PM
Pros and Cons of this technique? G Tubes / Valves 35 23rd October 2003 05:37 PM
Copyright ©1999-2017 diyAudio
