Old 23rd July 2004, 04:21 PM   #1
Default If I removed the rear chamber of an electrodynamic tweeter to enable dipole operation
What would its radiation pattern look like? Would it behave like a cos(a) chart?
If not, would it be possible to build an electrodynamic dipole (i.e. cos(a) dispersion) cone/dome tweeter that rivals today's best?
Old 23rd July 2004, 11:41 PM   #2
Old 24th July 2004, 09:18 PM   #3
Default Re: If I removed the rear chamber of an electrodynamic tweeter to enable dipole operation
If not, would it be possible to build an electrodynamic dipole (i.e. cos(a) dispersion) cone/dome tweeter that rivals today's best _monopole tweeters_?
Old 24th July 2004, 11:18 PM   #4
SY's Avatar
Roughly, but not exactly due to the differences in acoustic environment (e.g., radiation loading, diffraction) between front and back. These ARE short wavelengths we're talking about. If the front and back geometries and baffling are symmetrical, you'll get a closer approximation to dipolar.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 25th July 2004, 02:06 AM   #5
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
AudioVector have done this a long time...
And they have a channel/port that extends from the back of the element to the rear.
It makes a difference, even on the ScanSpeak Revelators
Arne K
Ars longa, vita brevis
Old 25th July 2004, 04:38 PM   #6
http://www.scandic.com.hk/hexadym.htm
Do you estimate that up to (at least) 3-4kHz, a bare HEXADYM motor would be roughly dipolar?
Old 25th July 2004, 04:51 PM   #7
SY's Avatar
Without a scale, it's hard to tell, but it looks like the hole in the magnet might be a significant load at the frequencies you're talking about.
Old 25th July 2004, 05:30 PM   #8
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
and it's horn loaded too! Maybe this will become the new fad-rip your tweeter apart and use it backwards. If you don't want dipole, then attach it to a small box filled with fiber.
Hmm , those Seas drivers are pretty pricey, but you only need one to try....
Old 25th July 2004, 06:43 PM   #9
GM is offline GM  United States
GM's Avatar
Funny you should mention this, on another forum the other day we were discussing pros/cons of removing the end caps of compression drivers (the diaphragm is mostly hemispherical (convex) from the rear) and stuffing the 1" exit, which would either make it a small aperiodically backloaded conical horn if baffle mounted, or a dipole if free air or OB mounted.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 26th July 2004, 03:04 AM   #10
...would it be possible to build an electrodynamic dipole (i.e. cos(a) dispersion) cone/dome tweeter that rivals today's best?
The reason I'm asking is because if this can be done, the effects of baffle diffraction would be much reduced (up until the tweeter starts firing into 2pi space, but then diffraction isn't a problem anyway) because of the cos(a) response - i.e. very little (to no) sound is radiated at 90 degrees off axis.
Tweeter chamber slogan2112 Multi-Way 3 18th May 2008 05:30 PM
6th Order Bandpass Subwoofer (rear & front chamber size?) nickthevoice Subwoofers 12 8th February 2008 10:01 PM
HT bass horn with vented rear chamber paulspencer Subwoofers 2 26th February 2006 06:02 PM
front loaded bass horn without rear compression chamber? paulspencer Subwoofers 9 28th October 2005 04:53 PM
NEO3 and NEO8 as dipole or in chamber? henriksommer Multi-Way 7 17th May 2004 10:34 PM
Page generated in 0.11237 seconds (73.73% PHP - 26.27% MySQL) with 10 queries
