Hi,i need your help,can i series the inductor to get my correct mh?Any effect on sound quality?
#2 |
Banned
Yes, you can combine inductors in series or parallel to arrive at a precise value; the same applies to caps. Don't sweat trying to get closer then 5% of recommended values.
#3 |
Two like inductors in series doubles the value, two like capacitors in series halves the value.
#4 |
Just note that it will usually be practically impossible to place somewhere where the two don't affect eachother, yes, I know it's possible in theory, but alas, not in the real world.
Also it generally sounds horrible .. so don't. Just have a larger value than you need and wind of wire from it until you hit the exact value. Simple and effective.
Hmm .. no .. I really haven't got anythig cool to say .. |
#5 |
Yes you can. The sound quality will be worse, mostly because you have more resistance. Interference due to coil orientation is in theory but practically I haven't recognized any difference. If you keep the same DCR (and winding quality), I doubt you can detect the difference. Usually in the crossover you make more serious mistake than just allowing the interference to happen
| Copper coil inductor vs. round core inductor | tomchaoda | Pass Labs | 7 | 21st September 2011 04:42 AM |
| Inductor DCR ? | mace | Multi-Way | 3 | 9th September 2007 10:41 PM |
| Inductor lot 875+ for the DIY | RAW | Multi-Way | 1 | 14th August 2007 01:23 AM |
| air core inductor vs. iron core inductor | WBS | Planars & Exotics | 5 | 7th May 2007 11:02 PM |
| WTB: INductor:0.2, 0.25, 0.33& 0.9, CAP: 2.7uF&8.2uF | gengis | Swap Meet | 0 | 6th July 2006 08:46 PM |
| Page generated in 0.08943 seconds (72.41% PHP - 27.59% MySQL) with 10 queries |
