I have this 8" Sub I am using with my computer, it's in a premade sealed box. I want to add a port to it. I used to know of an applet that given the specs of the speaker the enclosure could produce specs for the appropriate port to use. I no longer know where that applet is, though I have searched for it, I am still at a loss. What can I do to figure out what size port I can use and moreover what can I make the port out of? Thanks! |
#2 |
hey..you could try to download this free program to play around with
http://www.linearteam.dk/default.aspx?pageid=winisdpro |
#3 |
Thanks, I'll look into that program. I am still interested in more replies though!
#4 |
I'd love to help you model out your sub with the programs that i have (bassbox pro & winisd)
but I don't have the specs of your sub. The port size (volume) is dependent on the tuning frequency that you desire and the enclosure's internal volume. Maybe if you could be more specific, I'm sure you'll get more help from the guys here. Btw, you could buy the ports about any audio stores.. partsexpress.com is a reputable place you could buy from online if you're like me..I go the ghetto route and buy plumbing PVC pipes from Homedepot and cut up the pipes to my specs |
#5 |
Well unfortunately it is a rather cheap subwoofer. The company that made it, Roadmaster USA, doesn't have any real technical specs on the driver besides this manual
The enclosure is also made by Roadmaster USA. No datasheet or manual this time, at the most you could get information about it from this page, but I did measure the box myself and basically this is what I got 579.176 Cubic Inches which converts to .335 Cubic Feet of internal volume in the enclosure. The driver's manual reccomends over 3x that amount so I guess my measurements are wrong.. but I tried. |
#6 |
Any ideas people?
#7 |
ooooooooh it's ok peoples, I found that applet, thanks!
| Modding a XR45: adding USB port. | antorsae | Digital Source | 4 | 1st February 2006 04:21 PM |
| Adding Vol Port to this LM3886 Circuit! | FREQUENCY | Chip Amps | 12 | 12th March 2005 09:08 AM |
| enclosure port | sma | Subwoofers | 4 | 24th January 2004 04:47 PM |
| Adding a port | Howard | Multi-Way | 35 | 15th August 2003 09:06 PM |
| how far away from the enclosure wall should my port be? | slicemaster101 | Subwoofers | 1 | 15th April 2002 09:35 AM |
| Page generated in 0.10822 seconds (72.44% PHP - 27.56% MySQL) with 10 queries |
