Old 22nd July 2004, 11:29 PM   #1
Send a message via AIM to bhg41088 Send a message via MSN to bhg41088 Send a message via Yahoo to bhg41088
Default 2-way audax
Has anyone done a 2 way using the Audax TM025F9 tweeter and the Audax AP170G2 6.5 woofer? I would like to do this in a .3 cubic foot sealed box with an F3 between 75 and 80hz. I would like to use a 5khz 12db/oct highpass on the tweeter and a 6db/oct lowpass on the woofer. The woofer seems to roll-off pretty sharply right after 5khz, so 6db should be enough for it. This will be bi-amped with a Panasonic Xr25 reciever along with 1 12" woofer per side. Tell me anything about this that could help me. Should i use baffle step compensation? With an 8" wide baffle where does the baffle step occur? How close should i place the tweeter and woofer? I was thinking frame to frame.
http://www.partsexpress.com/pe/showd...number=276-156
http://www.madisound.com/AP170G2.html
Old 23rd July 2004, 04:38 AM   #2
help me!
Audax DIM Multi-Way 11 9th March 2006 08:34 PM
Audax Sd value Svante Multi-Way 6 28th April 2004 10:46 PM
Diy Audax sma Multi-Way 13 12th February 2004 06:44 AM
son audax sma Multi-Way 0 27th December 2003 11:40 AM
Audax HT xr628 Multi-Way 1 16th January 2002 07:42 PM
Page generated in 0.06862 seconds (68.37% PHP - 31.63% MySQL) with 10 queries
