Assembly foam - any good for damping?
Old 22nd July 2004, 02:37 PM   #1
Szczesiu is offline Szczesiu  Poland
Question Assembly foam - any good for damping?
Hello everybody - first time in here
Have a question about using an assembly foam for damping the closed enclosure with a Seas woofer. I could make space for cabling by insterting thin plastic hoses and removing them after pouring foam into the enclosure. Foam looks as it has some advantages over typical (loose) damping materials such as mineral cotton:
- it stiffens enclosure
- it seals all the gaps
- has got excellent adherence to wood etc.
- can be drilled cut etc. after stiffening
Anyone got any experience with it? If I asked a dumb question, please gently explain - why?
Old 22nd July 2004, 06:12 PM   #2
BillFitzmaurice is offline BillFitzmaurice  United States
Banned
If you mean expanding foam that cures rigid it will not work. Your cabinet must have a set volume of air inside to work properly and damping foam therefor must be open celled; expanded foam is closed cell.
Assembly foam - any good for damping?Hide this!Advertise here!
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 01:14 AM
Closed Cell Vs. Open Cell Foam-Which For Damping Loudspeakers? kelticwizard Multi-Way 25 10th July 2013 03:55 AM
Foam Surround Kits-Any Good? kelticwizard Multi-Way 9 23rd October 2002 01:39 AM
