Why burn in?
Why burn in?
Old 31st December 2009, 10:31 PM   #11
TrueSound is offline TrueSound  United States
Banned
Burn in in high-end audio is an excuse for the hobbyist to feel better about their lousy sounding stereo.
HAPPY NEW YEAR!
Old 31st December 2009, 11:08 PM   #12
john curl is offline john curl  United States
john curl's Avatar
Oh, is that how it works. What if it NEVER breaks in? ;-)
"Condemnation without Examination is Prejudice"
Old 31st December 2009, 11:15 PM   #13
Key is offline Key  United States
Break in with parts that have elasticity - speakers, cartridges - is perfectly legit and manufacturers of speakers will say that they design these things with the break in considered and calculated. I have seen a couple of speaker manufacturers explain the face to face break in technique as well. Only they give words of caution - do NOT play music through the speakers face to face and only do it with speakers that can handle large excursions. And it is only to break in the speakers faster I would think normal low level music over about 30-40 hours is much safer.
Old 31st December 2009, 11:20 PM   #14
Banned
Well that's a tough one -NOT, if it sounds lousy and that doesn't change then it still sounds lousy. If it doesn't sound lousy anymore then it either doesn't sound lousy anymore or you now like the old lousy.
Old 31st December 2009, 11:36 PM   #15
arande2 is offline arande2  United States
HAPPY NEW YEAR!
I have a woofer that I bought recently and I could barely push the cone in when I first got it. It also had LOADS of mechanical noise that I could not stand. Now after an extended period using it, I find that the mechanical noise has reduced to the point where I have to my ear right next to it when it is moving a lot to hear it. I also find the suspension compliance has increased in that now I can actually move the cone a bit.
As for how that affects sound, I did not do any testing, and cannot say anything.
Old 1st January 2010, 12:13 AM   #16
Rick J. B. is offline Rick J. B.  United States
Rick J. B.'s Avatar
You know I could always see the "burn in" issue with speakers because as has been said they do have suspension systems that will change over time. I know back when I had Lowther drivers they sounded different after a few hundred hours than they did straight from the box.
I recently was reading some information concerning some really pricey cables and the article referenced a break in period for those. Now I could be wrong, but that struck me as being complete **!
Rick
Old 1st January 2010, 11:21 PM   #17
Pano is offline Pano  United States
Pano's Avatar
Why burn in?
I think that we should differentiate between "Break-In" and "Burn-In".
Speakers definitely break-in. Anyone with a means to measure T/S parameters can easily verify that. It's mechanical.
Burn-In, on the other hand, is much harder to verify. It's supposed to be mostly electrical. Electrolytic capacitors might be the easiest to measure. (ask the photo flash guys)
But everything else.... ?
Take the Speaker Voltage Test!
Old 1st January 2010, 11:22 PM   #18
Oh I guess I am wrong I see a couple of manufacturers say to play music with one speaker wired out of phase and speakers facing each other. I thought I read one from a manufacturer that was much more picky than that but I can't seem to find it.
Why burn in?Hide this!Advertise here!
Mosfet burn jegandren Power Supplies 4 20th May 2013 01:46 AM
Burn in on speakers Nordic Multi-Way 5 16th November 2006 10:13 AM
will laziness burn my amp down?! fuzzball Tubes / Valves 27 18th May 2005 03:03 PM
Copyright ©1999-2017 diyAudio
