Old 20th July 2004, 10:09 PM   #1
Default making a driver into a coax?
HELLO! i just finished a pair of speakers (well...i built 5 boxes...yay for 5.1!) with the mcm 55-1870 drivers...they are a little lacking in the highs and i don't have much room on the boxes to add tweeters...unless i used some REALLY tiny ones...
so i was wondering if it was possible or hard to make them into coax driver? i have googled and the like but haven't found and REALLY good rescources...sooo...can you guys help me? thanks!
Old 20th July 2004, 10:25 PM   #2
Send a message via AIM to bhg41088 Send a message via MSN to bhg41088 Send a message via Yahoo to bhg41088
look up the CDT braxial series. Interesting and fairly good looking solution.
http://mainstreet-audio.com/cdtaudio/images/HD-53.jpg
Old 20th July 2004, 10:25 PM   #3
Timn8ter's Avatar
I fooled around with this a little but haven't gone back to it yet. Sounded pretty good for a prototype.
http://www.alegriaaudio.com/coral_op...le_project.htm
Old 20th July 2004, 10:29 PM   #4
hmmm...that seems like a pretty good idea...but this is a 5" speaker... so i'm thinkin that the tweeter is still gonna have to be tiny...any recomenations?
and could i just affix it with a dowel rod?
EDIT: maybe i could build a matching enclosure that i could just set on top of the box?
Old 20th July 2004, 10:39 PM   #5
Timn8ter's Avatar
Go to your local Radio Shack store and ask them to look up a model 40-1310 supertweeter. If they don't have it ask them to look up the stores in the surrounding area. They should be on clearance for $9.97 (at least they are here). It's intended to be an add-on tweeter in it's own enclosure and stand that sits on top of an existing speaker. It comes with a built in 2nd order XO set at 5Khz but you can easily remove it and add your own. I just used a single cap and padding resistor. Works great.
Old 20th July 2004, 10:52 PM   #6
HOLY CHEESE! they wanted to charge me 20 bucks a few months ago...maybe it was longer ago...
Old 20th July 2004, 11:12 PM   #7
what about that hivi that looks like a bullet at PE?
Old 20th July 2004, 11:23 PM   #8
i'd REALLY like to stay away from mounting the tweeter on the very top of the box...i just think that it looks ghetto...
i do remember seeing a speaker somewhere where the tweeter was mounted under the dustcap...but i don't think i could find anything small enough...
Old 20th July 2004, 11:40 PM   #9
madisound has a 10mm tweeter, its the Audax TM010A39.
Old 21st July 2004, 12:12 AM   #10
frugal-phile(tm)
planet10's Avatar
But the actual diameter is more like 35mm -- ApexJr has a version of this tweeter that can be carved down (if you don't want the mounting tabs) and stuck on a dowel attached to the (duscapless) polepiece ala the PHY-HP.
And i know he has a special price on these for diyaudio (the post has been moved to the Audio Vendor's Bazaar which should become visible any time now).
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Seas H1333 coax driver Q's weinstro Multi-Way 0 22nd May 2008 04:20 PM
are notch filters for compression driver sometimes helpful w. coax? freddi Multi-Way 2 21st November 2007 07:35 PM
Making a bass cabinet, driver selection. ruerose Instruments and Amps 21 29th October 2006 02:48 AM
Back Loaded Horn with Pro Coax Driver djdan Multi-Way 10 15th October 2004 01:45 PM
hum from tv coax bonsai171 Everything Else 17 4th April 2004 05:25 PM
Page generated in 0.09464 seconds (85.51% PHP - 14.49% MySQL) with 11 queries
