Which diaphragm shape has the greatest dispersion?
Old 19th July 2004, 11:46 PM   #1
454Casull is offline 454Casull  Canada
Default Which diaphragm shape has the greatest dispersion?
Or do they all equally radiate sound off-axis? The reason I ask is this:
"The concave dome allows a smaller diameter voice coil which is then better coupled to any given point on the dome. This concave shape also produces an almost perfect waveform (its main strength), reproducing the original signal with an accuracy that a convex dome never can. This accurate sound is also dispersed widely (its second main strength), down only a few dB at the highest frequencies even at 180 degrees off axis."
http://humanspeakers.com/diy/drivers.htm
Old 19th July 2004, 11:54 PM   #2
GRollins is offline GRollins  United States
The smallest one--relative to the wavelength being reproduced--is going to be the one with the best dispersion. The tradeoff being that smaller diaphrams produce less SPL for a given excursion.
Grey
Old 20th July 2004, 12:09 AM   #3
Ron E is offline Ron E  United States
Ron E's Avatar
The reasoning behind the human speakers blurb is that dome tweeters when they break up degenerate into a ring radiator the size of the voice coil. Using a smaller voice coil will give you better dispersion if the dome is breaking up. For hard domes where the breakup is outside the audible range, there would be no difference between concave/small VC and convex/large VC. As it is, even with soft domes, there is precious little difference.....
Focal domes use this technique, and it seems to cause more problems than it solves in the HF region. Both their kevlar and metal (Ti) domes have nasty peaks in the 15-20kHz range. IT would be interesting to find out if the human has this problem as well.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 20th July 2004, 12:18 AM   #4
Ah, that clears it up a lot! I guess their claim of being down only a few dB 180 degrees OA is pretty off.
Which diaphragm shape has the greatest dispersion?Hide this!Advertise here!
Greatest circuit ever (or weirdest) kenpeter Tubes / Valves 25 17th May 2009 08:56 PM
greatest expert for MK's TQWT sheets here? Zen Mod Pass Labs 0 7th June 2006 11:04 PM
Which Krell has the greatest sound Alex helge Solid State 5 5th April 2006 12:40 AM
one of the greatest orchestral recordings ever dorkus Music 15 7th February 2003 01:23 PM
Copyright ©1999-2017 diyAudio
