Old 18th July 2004, 04:32 PM   #1
Default Seas Excel M15CH001 vs AT CQ 15H520613SDK
Anyone had a chance to audition these two midrange drivers? Assume that the x-over will limit both drivers to within their Xmax, say over a range of 350Hz to 3-4kHz.
Thanks.
Old 18th July 2004, 05:40 PM   #2
I haven't listened to them actually but in the Hobby Hifi Magazine they said that Excel M15CH001 performed better than this list of drivers:
Audax PR170Z0
Audax PR170M0
Focal 6WM
Focal 7k6411
Scan-Speak 12M 4631G00
Scan-Speak 15m 4531k00
Beyma 605 ND
Visaton TI 100 M
& four cheaper Visaton drivers
Also Sherwin noticed that the Excel M15CH001 had almost the same qualities with the Accuton C^2 79.
BTW it is very intresting that the Sonus Faber Stradivari uses the C-Quenze 15H with the Scan-speak ring-radiator and some modified (?) Seas 10". While the TAF Oss Royal Excalibur uses the M15CH001 with the Scan-speak ring-radiator, with a Excel Paper 8" and a 10" woofer.
Here there are some intresting links:
http://www.taf-oss.nl/indexuk.htm (TAF Oss Site)
www.hsi-luidsprekers.nl/Sherwin.htm (Sherwin's loudspeakers)
here is the TAF Oss Royal Excalibur picture:
Old 19th July 2004, 10:57 PM   #3
Thanks for the feedback.
The M15 rear magnet assembly design looks like there would be very little in the way of internal reflections. I plan on optimizing the rear enclosure cavity in my next design. The 15H on the other hand has a magnet assembly almost as large as the cut out making this difficult. My only concern with the M15 is the 1mm xmax.
Old 19th July 2004, 11:32 PM   #4
David Gatti's Avatar
I agree. Xmax could be the decision maker. I was faced with the same choice some time ago, and decided to go for the CQuenze 15H to meet my SPL requirements when using a 2nd order highpass filter at 250Hz.
So it depends on the crossover freq and slopes you have in mind, and the cost of course.
www.geocities.com/gattiweb/delta
Old 20th July 2004, 01:55 AM   #5
David,
I have been following the progress on your Delta project with great interest. I am still 50/50 between these two drivers. I look forward to your results. Good luck!
Old 20th July 2004, 05:29 AM   #6
Hi Slogan. You must be patient!
Progress has been a little slow and at this rate it's going to be Christmas before I'm listening to them.
Back to the topic, I often wonder how significant the rear internal reflections off the magnet are. I haven't really seen any hard data to support the interference theories, and I think it could only come into play above about 2kHz.
WTB: Seas M15CH001 drivers pkpickard Swap Meet 16 11th December 2008 11:26 AM
Seas Excel W15 & W22 cdoggy81 Swap Meet 7 19th December 2006 01:47 AM
Peerless HDS 134 or Seas M15CH001 Hexadym stimpies Multi-Way 2 6th September 2005 01:49 AM
Seas Excel W26 compaired to Seas L26 (10") harruharru Subwoofers 9 11th March 2005 09:47 PM
Page generated in 0.09883 seconds (71.96% PHP - 28.04% MySQL) with 11 queries
