#2 |
Nice study. I have done something similar some time ago with a 8" Phy-Hp driver, don't have any pictures, only compared the results on the computer.
I also measured the differnets baffle sizes under an angle of 15 and 30 degrees. That's very interesting. When measuring under an angle the narrow response dips are not that bad. Response peakes on-axis are worse, they also apear under an angle, small dips are o.k. however because they will be compensated by the power response of the loudspeaker in the room. You won't see them anymore when you measure at a distance of 3 meters (open field that is, otherwise you are measuring the roomreflections, not the speaker) |
#3 |
hey wingman, do you think i would come near the same results with the peerless 850122 on the "h" baffle you used?
#4 |
please if somobody has saved the posted article by wingman can post it again here or somewhere else?
Thank You. Piergiorgio
Piergiorgio |
#5 |
http://www.troelsgravesen.dk/OBS.htm ,
#6 |
Thank You
Piergiorgio |
| Feasibility study | 454Casull | Multi-Way | 10 | 22nd March 2009 12:23 AM |
| MJK OB-bass study | skorpion | Multi-Way | 38 | 5th March 2008 10:46 PM |
| I want to study | NoBit | Digital Source | 3 | 12th January 2008 02:35 PM |
| starting to study amp designs | Clipped | Solid State | 27 | 19th April 2007 07:50 AM |
| a study of DF control | digi01 | Chip Amps | 5 | 16th March 2007 07:38 AM |
| Page generated in 0.07426 seconds (76.82% PHP - 23.18% MySQL) with 10 queries |
